Sponsored by: Innova
cd dj error
Old Sep 29, 2003 | 09:18 PM
shess62's Avatar
shess62
Unhappy cd dj error
how do i get my cd changer to work or how do i get rid of this error?
Old Sep 29, 2003 | 09:34 PM
badtoyzrule's Avatar
badtoyzrule
did you hook it up or was it professionally installed?
Old Sep 30, 2003 | 10:35 AM
black98f150's Avatar
black98f150
i think it means no disc in the player??????
Old Oct 1, 2003 | 06:38 PM
shess62's Avatar
shess62
this cd player came stock in my ford f150 lariat and it worked fine until i let my 16 yr old daughter use my truck and she called and said she got this error: cd dj error
Can anyone help
Old Oct 1, 2003 | 08:16 PM
black98f150
maybe you cant play that cd?
Old Oct 1, 2003 | 08:17 PM
PrPlayboy's Avatar
PrPlayboy
Did she put her own cd in? Home made CD's are the leading cause of errors. Either way you may need to reset the cd player by unplugging it (pulling the fuse). It should fix it unless the cd is stuck.
Old Oct 1, 2003 | 11:15 PM
badtoyzrule
If there is a cd stuck in there, do NOT try to get it out manually. This will not happen, you will only end up tearing up your face on the cd player. Try pulling the fuse like black said and see what happens, if that doesn't work, try pulling the harness from the player as well as the fuse. If all else fails, take it to the shop, it should still be under factory warranty. (Home made cds are the leading cause of cd errors, that is how I screwed my stock cd player before I ever got my system in my F250 XLT)
beartracks
Feb 21, 2013 05:20 PM
Swagtastic
Jun 11, 2012 07:39 PM
harknbark
Dec 16, 2010 05:43 PM
iflooru
Nov 19, 2008 10:51 AM
Hello
Nov 3, 2005 12:56 PM
