Tipped on side, blew smoke, rough idle, no power?
Last friday I was taking some friends fishing in my bronco, 351m, 1981, c-6, and I accidently got high centered in a ditch after some Chevy cut me off. I was really stuck was real close to rolling the bronco down a hillside about 20' , any ways I had it running while negotiating what to do without rolling it, then it started blowing black smoke out of the exhaust, I shut it off, then after i got it out it still smoked for about 2 minutes then was fine and ran well. Then on saturday while stoped at a stop sign it starts idling real rough, also it has no power now. I checked a couple of things, plugs are fine, checked out the cat, took it to my auto shop today and my teacher tried a couple of things but no luck. Any ideas as to what may have happened or how to fix it? Any ideas are greatly appriciaded because i am out of any. Thanks
Gummed rings, are you getting wicked blow-by? Stuck valve, it it running rough?
Try pulling the plug wires off the running engine one at a time, listen for the idle speed to drop, replace it and pull another. If you find one that doesn't make the idle drop, you might have found a stuck valve.
Running stock 2bbl motocraft, I thing you guys may be right about the carb, that does make sense, the more i think about it the more it makes sense. Well my father just said the same thing that you all said so I will be workin on the carb tommorow. Thanks everyone for all the help, this is why i love this web site.
great site
Great site, Ive learned alot already, I just bought a 83 f150 w/ 351 auto. It has been sitting for a couple of years. It was running rough and popping under load. I thought it was water in fuel in dumped in fuel dry and filled the tank with premium. It helped alot but when I took it out on the hway to blow it out it began to smoke bad and thought I blew a main seal or something ( im not a wrechhead yet) anyways it runs fine now but smoke out the driver side when it warm up. and it blows oil out the oil filler cap in the valve cover. Im not sure if it is a stuck valve or a hole in the piston or what. Any suggestion as to were to start would be appreciated. I bought the truck to learn on but this was a bit faster than i was planning for.
