timing question
Old Sep 29, 2003 | 09:06 PM
farmer joe's Avatar
farmer joe
timing question
I was just wondering what the best timing setting would be (best fuel milage/power without causing damage) for my balanced 460 9:1 compresion, RV cam, 750 electric choke edlbrock, wiend stealth aluminum intake. Your pinions and suggestions are much apreciated!
Old Sep 29, 2003 | 09:15 PM
ranger429's Avatar
ranger429
i set mine at 6 BTDC, i got a 429 with holley and stealth and run 10 to 1 with a cam, works good there
Old Sep 30, 2003 | 11:58 PM
LxMan1's Avatar
LxMan1
I run mine @12BTDC.
Old Oct 1, 2003 | 06:51 PM
timjk69's Avatar
timjk69
This has always worked for me. I just advance the timing a couple degrees at a time till it pings, then back it off again. Anyone else do this?
Tim
Old Oct 2, 2003 | 12:17 PM
84ford460's Avatar
84ford460
I usually use a vacuum gauge to set mine. That way the timing is right for whatever elevation you are at. I live @ 7200 ft.
Old Oct 2, 2003 | 01:30 PM
ClydeSDale's Avatar
ClydeSDale
Originally posted by lxman1
I run mine @12BTDC.
Me too!
It seems to be the universal timing advance for the 460.
Old Oct 2, 2003 | 06:24 PM
phooka's Avatar
phooka
i recently bought my 1979 e350 trailer special witha 460.. advance was set to about 0.. (eep!) i moved it to 12 but it pings a little sometimes when i get on it.. what grade of gas do you guys run? I was running the cheap stuff... last fill i put 89 in to see if it makes a diff.. still waiting to see.
dale
Old Oct 2, 2003 | 10:07 PM
84ford460's Avatar
84ford460
I was running 87 octane until I did my Buildup. It ran ok,but on 91 octane I was getting better performance and fuel mileage.
Now I run only 91 in my truck. Gets spendy sometimes but I feel it is worth the extra mileage and power.
Larry
1984 F250 4x4 w/460
1982 Mustang GT
1993 Explorer 4x4
Old Oct 3, 2003 | 12:57 PM
ClydeSDale's Avatar
ClydeSDale
Before I had my distributor recurved I would get pinging under load @ 12* unless I ran mid-grade fuel. After the recurve I could run anything without problem.
The guy who did the work said rebuilts are usually mismatched because of the variety of applications and seldom are the springs and weights correct. I provided him with engine rpm's, vacuum readings, speeds, fuel information along with a bunch of other stuff and he set the timing curve to match my needs.
We did a 2,600 mile trip to Colorado towing our 5th wheel this last July running altitudes from ~600 to over 10,000' and used octanes from 85 to 91 with no problems, no pinging and lots of power.
A performance matched recurve is well worth the time and money. I've got a good ignition service I can recommend in the Mpls-St Paul area if anyone is interested.
Old Oct 3, 2003 | 10:06 PM
proeliator's Avatar
proeliator
I actually run mine at 17 initial. Allot I know, but I run top grade fuel and my dizzy's curved for my motor. What I recomend to most folks asking this question is to put it at 10btdc, see if it pings under load with the fuel you run...then try another two degrees...if thats still good then another two, etc.
Old Oct 8, 2003 | 12:18 PM
rsrxc700's Avatar
rsrxc700
re-curve info needed
Hey ClydeSDale, I would like the info on the shop that did your recurve. Mine was pinging bad at 11.Mine also goes to like 24 degrees at like 1500rpm, seems too much to me, anyway I would like to get it recurved. Thanks!
Old Oct 8, 2003 | 11:23 PM
LxMan1's Avatar
LxMan1
I run 87 octane @ 12 degrees. No problems. I also do run the vacuum advance on ported vacuum, not manifold vacuum.
Jimmy
Old Oct 9, 2003 | 06:41 AM
phooka's Avatar
phooka
Jimmy
I'm running about 6 right now on the non-emissions port of my edelbrock.. i am not sure what the difference would be with the emissions port (specified in the documentation).. but i get some pinging still under load with mid-grade (89 oct) gas. kinda annoying.
dale
