Sealed Power ring orientation
Old Feb 10, 2019 | 12:12 PM
BayStYat's Avatar
BayStYat
Te directions are not clear. Does the ring with the dot go on the top grove or bottom grove?
Old Feb 10, 2019 | 06:37 PM
70FE250's Avatar
70FE250
If it has a dot, it will need to be facing up towards the top of the piston. If there is no dot present then you will need to orient the outer ridge with how instructions recommend
popspuller6.9
Mar 29, 2013 08:15 PM
Argess
Apr 25, 2009 10:25 AM
yellow72f100
Dec 16, 2006 07:35 PM
yak
Feb 24, 2003 01:20 AM
Ford79
Exhaust Systems
Jun 25, 2002 11:07 PM
