mixed up rings
Old Dec 9, 2006 | 04:32 PM
yellow72f100's Avatar
yellow72f100
mixed up rings
Happy Holidays everyone. I was inspecting my rings prior to putting them on new pistons and now I dont remember which group of compression rings is top and which is the 2nd. Both groups are the same size and the only identifing mark is a dot on both groups. One group is more blackish and one is more grey. That is the only difference. Thanks.
Old Dec 9, 2006 | 04:57 PM
bronco521's Avatar
bronco521
is there a bevel on the inside of one of the rings?if so i think these are the second ring.dots go up.
Old Dec 15, 2006 | 08:05 PM
mvoeller2's Avatar
mvoeller2
If you got a moly ring set, the "brighter" looking one goes on the top ring. Other wise you can't go buy if it has an inside bevel for the location of the ring, because different ring manufacturers sometimes have bevels on one ring, both rings, or neither. Best bet is to get a hold of the manufacture to be sure.
Old Dec 16, 2006 | 07:35 PM
baddad457's Avatar
baddad457
A Moly faced ring will have a visible moly groove on the face of the ring. That ring goes on top. If neither ring has the moly groove, you can install either in either groove. And as the others have posted, if there's a beveled inside edge or dot, that side goes up.
