For my 1994 F150 5.0 w/ cruise I see several throttle cable replacements listed when searching. Which one is the correct one for this application?
Pioneer CA8681 #F1TZ9A758K 43.28 Inch
Pioneer CA9028 #F4TZ9A758L 43.25 Inch
ATP Y1183 #F1TZ9A758J, F4TZ9A758L 43.25 Inch
ATP Y614 #F1TZ9A758J, F4TZ9A758L 40 Inch
ATP Y617 #F1TZ9A758K 44.5 Inch
The Pioneer CA8681 looks to match the best to the original throttle cable. But on Oreilly, it states without cruise control. The CA9028 doesn't specify with or without cruise control, but doesn't as closely match the look/design of the original.
The throttle cable should be the same with or without cruise control. My '94 originally with a 302 and non cruise, is the same cable that's on there now with cruise control I installed from a junkyard truck. Hope this helps some?
That is what I was thinking, since there is a separate cable for cruise.
