ignition wire getting hot
Old Feb 13, 2019 | 01:20 AM
gatorjaws's Avatar
gatorjaws
Thumbs up
Okay, you guys were spot on! Replaced resistor wire with reg and all is good! Thanks again, gatorjaws
Old Feb 13, 2019 | 01:24 AM
gatorjaws's Avatar
gatorjaws
ok, Ill keep an eye on it but there were no instructions that came with the distributer on wiring or anything else for that matter.
Old Feb 13, 2019 | 01:40 AM
Christmas's Avatar
Christmas
I would still bet it needs the full 12v.
Old Feb 13, 2019 | 01:43 AM
Christmas's Avatar
Christmas
This modern stuff does not rely on a muted voltage.
Old Feb 13, 2019 | 03:28 PM
charliemccraney's Avatar
charliemccraney
Ask the ebay seller for instruction.
Old Feb 14, 2019 | 09:04 AM
gatorjaws's Avatar
gatorjaws
yeah, I asked right after i received the distributer and no responce. let me ask u this: what will happen if it needed the resistor,what should I b looking for? will it burn the new wire ? will it burn the ignition switch? What should I b on the lookout for?
Old Feb 16, 2019 | 09:51 AM
Tedster9's Avatar
Tedster9
What exactly is it, a chinesium HEI clone?
What you're looking at is whether the current (amperes) through the primary circuit will exceed spec and burn something up.
The ballast or resistor does reduce the voltage, but it's the current reduction (heat) that is the actual purpose. You can get an idea by measuring the ohms resistance of the coil primary winding. Then use Ohm's law to figure how many amperes are flowing. A true HEI didn't use a ballast resistor, as I understand it the current was limited by the use of transistors. I would be surprised if the counterfeits have this feature though.
Jim Lovell
22
Oct 9, 2018 12:14 PM
Pinzer
Electrical Systems/Wiring
18
Jan 19, 2016 11:13 PM
jdmports22
Feb 7, 2014 08:39 AM
Bill W
Sep 29, 2007 01:21 AM
daggerNC
Oct 19, 2004 10:01 PM
