Not starting....
Old Feb 8, 2019 | 02:26 PM
grad98cofc's Avatar
grad98cofc
Not starting....
Hello, I've been having issues with my '94 F350 Dually. It has a gear splitter on it to help with pulling heavy loads. It's a hard shifter, so I had the PSOM repaired. Didn't help. Replaced the VSS...didn't help. I read that once you replace the VSS, you have to "reset the computer" by unhooking the battery. So I unhooked the positive lead of my battery. Since then, I can't get it to start. If I try to jump it off a running car, it won't turn over. If I hook it up to a battery charger it just makes a loud fast clicking sound when I try to start it. And the chime is really fast too. I took the battery in to AutoZone, they said it's reading full charge. (My charger said the same). Did I short something out??
I replaced the starter solenoid earlier this year, so that's not the problem (I think). Is it the starter? The alternator? Help! Arrgh!
Old Feb 8, 2019 | 02:55 PM
Tedster9's Avatar
Tedster9
"12V" doesn't mean anything, a full charge is 12.8 volts. Dead is close to 12.0V. Decimals are important with starting batteries. Even if the open circuit voltage is OK, the battery needs to be tested while under load. They should have done that when you took it in. There are some field tests or indications when installed, for example are the headlights bright? Do they dim or cutout completely when trying to start?
Glaser67's Avatar
Glaser67
What happens when you jump the starter solenoid? Does it cank?
Old Feb 8, 2019 | 03:10 PM
grad98cofc's Avatar
grad98cofc
I don't know how to do that
Old Feb 8, 2019 | 03:21 PM
grad98cofc's Avatar
grad98cofc
When I have it hooked up to an external jump box (75amps) it only clicks
Old Feb 8, 2019 | 03:26 PM
Freightrain's Avatar
Freightrain
"Typically" Autozone will tell you that you need a battery if it is anything below their charts. So if they didn't say anything then it's my guess it's fine.
Now, I wonder since it worked fine before you removed the RED cable. I wonder if you have a bad cable? They tend to rot off inside. If it was fine til you twisted it out of the way? I'm wondering if that is an issue.
Have the car that jumped it hook directly to the starter solenoid(next to the battery. If it starts, then the cable is faulty.
Here is a video showing how to jump across the solenoid:
Old Feb 8, 2019 | 03:37 PM
grad98cofc's Avatar
grad98cofc
https://www.youtube.com/watch?v=SJL0DD8gJbY
What do you mean "have the car that jumped it hook directly to the starter solenoid"? Are you talking about doing whats in the video you posted, or something else?
Old Feb 8, 2019 | 03:45 PM
Tedster9's Avatar
Tedster9
My uncle has a snoblower...? We're trying to help you, but you have to do your part too,, read the question, and answer the question.
Old Feb 8, 2019 | 03:48 PM
grad98cofc's Avatar
grad98cofc
Headlights are bright when hooked up to external source.
Old Feb 8, 2019 | 04:17 PM
Tedster9's Avatar
Tedster9
Sounds like you got everything pretty well figured out then, I guess.
Old Feb 8, 2019 | 04:26 PM
grad98cofc's Avatar
grad98cofc
Dude, either help or don't. Your snark is neither appreciated nor needed. We can't all be Ford gods like you. HEADLIGHTS ARE BRIGHT WHEN HOOKED UP TO AN EXTERNAL SOURCE WHILE TRYING TO CRANK. Better?
Old Feb 8, 2019 | 05:04 PM
Dean06919's Avatar
Dean06919
Put the transmission in park, set the parking brake, turn the key to the run position, open the hood. Use a large screwdriver and jump the fender mounted solenoid as in the video. Does the motor turn over and the truck start? If not, use your battery charger set to start or use another vehicle with jumper cables, and put the positive wire on the solenoid post that the battery wire hooks to, negative goes to ground. Now use the big screwdriver to jump the posts. What happens?
Old Feb 8, 2019 | 05:27 PM
grad98cofc's Avatar
grad98cofc
Ok, I did it both ways.
1: just jumping the solenoid: nothing happens...no turn over, no click, nothing.
2. Hooked up the battery charger set to start, put the + cable on the solenoid post, - went to ground. When I jumped the posts, it didn't turn over, all I got was a click. That's it.
Thanks.
Old Feb 8, 2019 | 08:39 PM
Tedster9's Avatar
Tedster9
No, not really.
What we want to do in this instance is see if the juice from the battery is making it where it needs to go, in addition to whether the battery itself is choking under even a minor load. It's kind of a poor man's diagnostic. Hooking a charger or jump box up confuses things and doesn't tell us what we want to know. I'm not trying to be a *****, there are reasons for asking certain steps to be done a specific way, it saves time and without writing a novel explaining all the whys and wherefores.
I don't think anything should have shorted out, disconnecting and reconnecting the positive. Was it disconnected for a long time? Has it been real cold where you're at? Just thinking outloud. I still would want to get a warm and fuzzy on whether the battery decided to crap itself. If AutoZone sez it's OK, I guess so. Did they do an actual load test or diagnostics though? Make sure all the ground connections are clean, and tight.
Old Feb 8, 2019 | 08:56 PM
grad98cofc's Avatar
grad98cofc
No, not really.
As far as I could tell, they just ran a diagnostic. The guy didn't say anything about being under load. I will check the connections. Per another suggestion, I tried jumping the solenoid, both by itself and with an external power source. Got nothing by itself, got a single click with external power.
The original disconnect was just off for about 10 seconds, then back on. It's real cold now, but it wasn't when it happened the first time. Others have suggested a bad cable? I dunno.
