Flushing out and replacing fluids
Old Feb 6, 2019 | 01:28 PM
92XLTF150's Avatar
92XLTF150
I have a 1992 F150 5.0L XLT 2wd that has been sitting for about 2 to 3 years. Which, if any, systems should I flush out completely and which systems should I just add fluids.
Old Feb 6, 2019 | 02:22 PM
Freightrain's Avatar
Freightrain
Depending on how well it was maintained before and where it was stored, I'd do at least the oil change. It really all depends on what you want to do.
You could do transmission, coolant, then add in brake fluid, power steering fluid.
Old Feb 6, 2019 | 02:58 PM
92XLTF150's Avatar
92XLTF150
Thanks, I really just want to get it running well and eventually try to get as much power as I can out of it, but that's going to be a lot later. I want it to be running well enough to be a daily driver not that I plan on making it my daily, that's just my goal.
Old Feb 6, 2019 | 05:05 PM
TexasGuy001's Avatar
TexasGuy001
I would change all the fluids and filters etc before driving it very much and definitely change the oil before driving it at all.
I would not flush the transmission though. Just drain the pan and torque converter if it has a plug. Then replace the filter.
The brake fluid might be something you could hold off on at first if they work, but I'd get to that at some point.
See if the differential is LS or not. If it is, I would change that too.
I would not just top off any fluids except for short term.
Old Feb 6, 2019 | 06:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I have a totally different view. I'd flush the transmission and not replace the filter.
Old Feb 6, 2019 | 08:09 PM
TobyB's Avatar
TobyB
...and I'd do the brakes and coolant before driving it, and everything else after I made sure it ran well enough
that I really wanted to keep it.
But the short answer is that, as long as everything works, just put some fresh gas in and be gentle
with the brakes, as they may boil easily.
we're all different,
t
Old Feb 6, 2019 | 09:26 PM
TexasGuy001
Almost no one recommends this. I'd rather leave the old fluid and not touch it.
Old Feb 6, 2019 | 09:56 PM
Mark Kovalsky
Why don't you do this with the engine, too?
Old Feb 7, 2019 | 08:19 AM
Freightrain
Ok Mark, knowing your transmission knowledge, why would you leave the old filter in it? Just curious.
I know with age the lubricity of the ATV goes away and you get shutter. So, not knowing the mileage or the maintenance of the truck, I would suggest a service to just make sure. I'm assuming you are just using a cooler line to change out the fluid only? Not having to deal with dropping the pan. Though even with my hatred of automatics, I've been able to service a few of mine though the years without issue. No leaks, no mess.
Old Feb 7, 2019 | 07:16 PM
TexasGuy001
Everyone older knowledgeable mechanic I have ever spoken to says to drain as much fluid as possible and replace the filter. Not one of them ever suggested having a flush performed.
Old Feb 7, 2019 | 09:35 PM
Mark Kovalsky
The filter is more than a screen, but not a lot more. If there is enough junk in it that it needs to be replaced, the transmission has already failed.
I know of old mechanics that also say to never flush the trans. In my opinion, they are basing their claims on 1960's transmission technology. If that's what you want to follow, go for it.
Old Feb 8, 2019 | 01:13 AM
TexasGuy001
You are really the fist person that I have ever really heard suggest never changing the filter. The filter is more than a screen and needs to be changed. It is an easy task, so I'm not sure why your are against changing the filter, but whatever works for you.
Since I first joined nearly 20 years ago, the general consensus on this forum has always been a fluid and filter change works best on these trucks
Another option is to try to let the system pump the fluid out from the hose under the radiator and keep adding though the dip stick tube.
The only shops I have ever been in that recommend a transmission flush have been the quick lube type places.
As they say there is more than one way to skin a cat, but I'll stick with what I know works. We've gotten hundreds of thousands of miles of service out of our vehicles this way.
Maybe flushes work great on the new designs.
Old Feb 8, 2019 | 08:17 AM
Freightrain
I understand the thought of the fact if the filter is clogged up, the transmission is basically worn out(all the clutch material is worn off). But for a few bucks and if you want to know what is really going on with it, so I would drop the pan and do a full service. You're in there, might as well for the few bucks it cost.
I remember hearing that once a transmission gets "xx" amount of miles, don't service it. You're apt to knock crap loose and screw it up. Leave a sleeping dog lie kinda thing.
Heck many new cars don't even have a way to add/check transmission fluid.
Old Feb 8, 2019 | 08:18 AM
Mark Kovalsky
I know what the filter is like. Have you seen my signature? I was an Automatic Transmission Engineer at Ford from 1988-2007. I also owned an auto repair shop for a few years. I'm rather familiar with this hardware.
I'm not against changing the filter, I just think it isn't worthwhile. If you want to change it, have at it. You won't hurt anything, but you will spend money that doesn't improve the trans. The old filter isn't hurting it unless the trans has already failed.
Yes, I've seen that, too. It doesn't mean I agree with it. I believe that they would have had identical results if they only changed the fluid. Also changing the filter didn't hurt it, nor did it help it.
And that's what I call a transmission flush. https://www.ford-trucks.com/articles...-transmission/
I DO NOT recommend the flushes where they put a solvent in the trans, run it for a while, then change the fluid. I believe those do more harm than good.
And I've had hundreds of thousands of miles of service using my methods.
Old Feb 8, 2019 | 08:24 AM
Mark Kovalsky
I also remember hearing the earth is flat. I don't believe either one of those.
I'm not aware of a single transmission that the fluid level can't be checked, or fluid added. I do know that many transmissions are VERY hard to add to or check, but it's still possible. You just need a lift and tools. There is no dipstick.
One of the transmissions I worked on when I was at Ford was the 5R5N in the Lincoln LS. It was the first automatic at Ford without a dipstick. You had to have the car in the air, remove a plug inside a standpipe in the pan, and add fluid to the trans through a fill plug to set the level. Many people said you couldn't check or add to that trans, they just didn't know how to do it, and it wasn't easy.
