If the actuator is bad, then that would stop the rod attached to the tab from moving up and down with power right?
my drivers rear is not moving and after I opened the door up I found that the buzzing I hear when I hit the lock button is coming from the actual lock...
so, do I need to replace the actuator or the physical lock? Please help, I'm lost
I'm special. I just realized that the part in question is the actuator...dont mind me
Reason: I'm an idiot
