solid state ignition system amplifier module
Old Feb 6, 2019 | 10:56 AM
mem's Avatar
mem
I have a 1975 F350 with 390 engine.
This vehicle has a solid state ignition system amplifier module which might be defective. There is sticky fluid under it. The vehicle will not start.
I tried the usual auto parts stores, eBay, and the Ford dealer. No one so far has this part.
Does anyone know where I can get a replacement?
Thanks.
Old Feb 6, 2019 | 02:07 PM
DB429SCJ's Avatar
DB429SCJ
https://www.rockauto.com/en/catalog/...ule+(icm),7172
Old Feb 6, 2019 | 03:13 PM
Thunder:Raven's Avatar
Thunder:Raven
Every parts store has them or can get them within a day. We typically call it an ignition module, brain box, etc.
Old Feb 6, 2019 | 03:15 PM
mem's Avatar
mem
Thank you. I forgot about them.
Old Feb 6, 2019 | 10:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1975 DuraSpark ignition module is 1975 only: D5AZ-12A199-C (Motorcraft DY-166-B) / Obsolete
Module marked with ID numbers: D5AE-12A199-A1A or A1B or A2A or A2B or A2C or A1D or A2D
1975 F100/350, Bronco & Econoline and all 1975 FoMoCo Passenger Cars.
Note: While DuraSpark electronic ignition was introduced in 1974, not all had it until 1976.
btw: Be aware that inside the distributor is this: D4PZ-12A112-A .. Stator aka Magnetic Pickup Coil (Motorcraft DU-1A) / Available from Ford & auto parts stores.
ALL 1974/79 FoMoCo V8 vehicles with DuraSpark except 1979 LTD/Grand Marquis 351W with EEC (Electronic Engine Control aka on-board computer).
When this puppy fails, just like the module...the vehicle will not start. Most Ford techs replaced both the module and the stator.
Both the 1974 & 1975 modules were such turds, that Ford techs referred to DuraSpark as NeverSpark!
Rick_Fury
Dec 10, 2011 10:51 AM
Holiver31
Mar 9, 2011 07:10 AM
farmnaggie
Mar 7, 2006 08:44 AM
bossman32
Mar 7, 2003 10:31 PM
