5.8 (351w) exhaust manifold studs
hello, my 97 F250 has an exhaust tick. I am attempting to remedy this by snuggling up the loose studs/bolts. All are good except for the two inner threaded studs which the oil dipstick tube and some other bracket mounts to.
the problem: while these studs spin freely in the block, the oil dipstick tube nut is kinda seized to the other integral stud nut.
I have two questions:
1. What size is the inner stud nut? It appears to be smaller than the other 14mm nuts. Like 12 or 13?
2. When I attempt to loosen the nut on the oil dip tube, it spins the whole stud and moves the dipstick bracket! (Kind of like when you double up nuts to install or remove threaded rod). How can I separate these ?
thanks in advance.
thanks in advance.
I would cut the nut holding the dip stick tube and other accessories and then see of the stud comes out in one piece. But like Conanski says it may already be broken. I actually just had the same thing happen the other day and the stud came out. Dorman makes a replacement manifold bolt/stud kit.
Have you had good luck with those? I am nervous about the fastener quality and haven't addressed this noise completely yet. Also, with red Loctite, what kind of torque should I not exceed when installing these or tightening them. I am afraid by the way one of mine felt, I will be needing a heli-coil.
As I expected, the stud was not broken and came freely out the block.
it was in fact seized to the dip stick tube nut. I now have a new problem—as I was fighting with it the dipstick drive came straight out of the block!
I do not know how or where to reinsert it! Does it go under or over or through the exhaust manifold?
can someone help?
Does the tube slide through the exhaust manifold? If so, between which cylinders? I have no idea where this hole is and can't see a thing.
kennyfzj80
13
12-05-2017 06:51 PM
annaleigh
18
11-26-2015 05:39 AM
