Help with Identifying Engine & Trans
Old Feb 4, 2019 | 07:01 PM
Fleetwood271's Avatar
Fleetwood271
Hey Guys! I'm new here and have just bought a 1969 Ford F100. Based on the VIN, the engine has been replaced. It now has either a 289 or a 302. From what I have read these two engines are identical except for the stroke on the 302 is 0.13" longer.
It has a 3 speed manual shifter in the floor, but I have not idea if the trans has also been changed or if the original is still in it.
If I get under the truck, what do I look for in order to identify the trans?
The shifter stick is a Hurst and it hits the bench seat in 1st and 3rd.
I'd like to get a taller stick to clear the bench.
Any help would be appreciated.
Oh....here's a shot I did yesterday after I washed it.
Old Feb 4, 2019 | 08:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1969 F100 could have had a 302 originally. 289's were only installed in 1963/68 cars, 1966/68 Bronco's.
Old Feb 4, 2019 | 08:02 PM
Fleetwood271
The VIN shows it originally had a 6cyl in it. How can I figure out what trans is in it?
Old Feb 4, 2019 | 08:09 PM
NumberDummy
It could be the Ford type 3.03 3 speed M/T all synchromesh, or possibly the Borg-Warner T-85N 3 M/T with overdrive, but neither would have had a floor shift originally.
4th digit of the VIN is the engine code: A = 240 1V I-6; B = 300 1V I-6; G = 302 2V
TRANS code stamped on the Warranty Plate. B = Warner T-85N 3 speed M/T with Overdrive // C = Type 3.03 3 speed M/T
Old Feb 5, 2019 | 01:40 AM
GaryKip's Avatar
GaryKip
Wow, that is a very nice looking truck. Congrats on a great find!!
Old Feb 5, 2019 | 06:37 AM
lilorbie's Avatar
lilorbie
Your truck looks Bitchin. the only thing i would change , is to put my name on the title.
Old Feb 5, 2019 | 12:23 PM
Fleetwood271
Thank you! Yes, I feel fortunate to have found it in this condition.
Old Feb 5, 2019 | 12:24 PM
Fleetwood271
HA! Thank you!
Old Feb 5, 2019 | 02:00 PM
Freightrain's Avatar
Freightrain
Very nice truck!!! Looks like someone did a very nice job on the paint. I love that color!!! Seems I've seen pics of that truck somewhere? That color is hard to miss. Was it on Ebay?
Sounds like it has the std 3spd transmission, nothing special about them.
The motor, could be anything. If you want, pull a plug and run the piston to BDC and stick a coat hanger down. Mark it, then roll piston to TDC and mark. Then measure. The 1/8" might be hard to determine unless you get real exact measurements.
Old Feb 5, 2019 | 03:21 PM
Fleetwood271
Yeah, the VIN has an A as the 4th digit, so I know the engine was originally the 240 6cyl.
Warranty Plate has a C, so if it is the original tranny, it's the Ford Light Duty, right?
Rear Axle code appears to be an 09, so that would be 3.70, correct?
Old Feb 5, 2019 | 03:23 PM
Fleetwood271
Yes, it was on Ebay. I didn't buy it on there however. I contacted the place that had it on consignment and bought through them.
Old Feb 5, 2019 | 09:49 PM
NumberDummy
cdouglas75
Apr 2, 2018 11:44 AM
Texas_Doug
Jul 10, 2014 11:26 AM
Ohio Ford Farm
Jun 18, 2009 03:53 PM
juchertf100
18
Jan 26, 2007 05:49 PM
MW95F250
Jan 2, 2003 10:41 AM
