Transmission options
Old Mar 31, 2018 | 08:49 AM
cdouglas75's Avatar
cdouglas75
hey forum friends
almost time to take the old girl out of storage. I have been throwing around the idea of switching transmissions. The truck currently has the 4 speed imposter hooked to the 302 with the old z bar clutch. The P.O. installed this trans and I think it was out of a Granada. Probably need to replace the clutch this year and figure out the linkage but I was thinking maybe a trans upgrade was in order at the same time. I don’t want to break the bank but thought I would put it out there to the community for recommendations. Thoughts on an appropriate auto? Top Loader? What have you guys done? What should I avoid?
Thanks
Old Mar 31, 2018 | 11:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by cdouglas75
hey forum friends
Are you sure this "imposter" was swapped in? The RUG SR-OD Single Rail 4 Speed Overdrive was an option in 1978/83 F100/150 2WD's with 300/302.
Also optional in cars like 1977/80 Granada, 1978 Mustang II, 1979/83 Mustang/Capri.
Old Mar 31, 2018 | 11:16 AM
cdouglas75's Avatar
cdouglas75
Almost positive. The linkage is cobbled together and the shifter location in the floor is not in the original position. Likely to accommodate the tail housing on this trans. P.O. told me it has a three speed with bull low when he got it and he swapped in this trans. Told me it was a 4 sod top loader from a mustang but it is definitely the 3 spd with OD “top loader imposter”.
Old Mar 31, 2018 | 10:40 PM
cdouglas75's Avatar
cdouglas75
hey ND...any chance you have a diagram with part numbers for the linkage on the 3spd with OD?
Old Mar 31, 2018 | 11:35 PM
NumberDummy
I have the pics, but the problem is, there are three different types of shift levers.
Is the shift lever/linkage mounted on the left side of the trans, or does the shift lever fit directly into an extension behind the trans case?
Old Apr 1, 2018 | 06:12 AM
Blue and White's Avatar
Blue and White
A 4 speed with overdrive is pretty nice in these trucks if you like manual. I do not know that particular transmission however. Does it have issues?
If the transmission is fundamentally OK I would consider cleaning up the linkage, puting a clutch in and run it.
Old Apr 1, 2018 | 08:21 AM
cdouglas75's Avatar
cdouglas75
the linkage is external on the left side of the trans.
Old Apr 1, 2018 | 10:51 AM
meangreen92's Avatar
meangreen92
I thought all the overdrive 4 speeds had the internal linkage, hence the Single Rail designation, but I don't really know. Are there any numbers cast into the sides of the gearbox?
I remember reading an article in Hot Rod many years ago where they took the SROD guts and put them in an early Mustang's 4 speed case so the owner could have overdrive, and they took those early direct-drive guts and put them into the SROD case in an '82 Mustang GT, to achieve more strength and better acceleration! Machining was required as I remember...
I think the SRODs are weaker due to extensive use of aluminum parts like the case itself if I'm not mistaken.
Old Apr 1, 2018 | 11:15 AM
willowbilly3's Avatar
willowbilly3
There were actually 3 completely different 4 speeds with 4 overdrive (3+OD) I think the one he has is the old cast iron case with external shifter that is very similar to the old car top loader. Then there was the single rail over drive (SROD) and the least common is the top shift aluminum case one.
Old Apr 1, 2018 | 11:21 AM
NumberDummy
If this is the case, the trans is not from a car.
Here are two pics of the SR-OD with external linkage.
Upper pic from F100/150, lower pic from Econoline.
Old Apr 2, 2018 | 07:27 AM
willowbilly3
Sorry, double post.
Old Apr 2, 2018 | 07:39 AM
willowbilly3
I think what you have there is the SMOD, not the SROD. It's hard to find all the info and images in one place. I couldn't even find a picture of an SROD but here is some helpful info .
Ford Truck Manual Transmissions
Old Apr 2, 2018 | 11:44 AM
NumberDummy
I've never heard of an SMOD and there's no listing in the parts catalog for it.
The applications for the O/D transmissions in this chart are wrong.
RUG SR-OD Single Rail 4 Speed Overdrive: 1977/83 misc. Passenger Cars 200/250/302 // 1978/83 F100/150 2WD 300/302 & 1978/87 E100/250 300/302/351W
RTS TS-OD Top Shift 4 Speed Overdrive: 1984/87 F150 2WD/4WD & Bronco 300/302.
SR-OD has external trans linkage (see pic in post 10) in 1978/79 F100/150 & 1978/87 Econoline.
1980/83 F100/150 SR-OD & 1984/87 F150 2WD/4WD & Bronco TS-OD: There's no linkage, as the shift lever fits into an extension behind the trans case.
Murpheyyo
Nov 11, 2017 06:13 PM
skyway0018746
Dec 21, 2013 06:16 PM
300I6VAN85
May 4, 2006 09:50 AM
captainkirk
Oct 18, 2005 02:09 PM
dotcentral
Jun 11, 2004 10:00 PM
