I am replacing the bushings on my front leaf springs on my 1960 f100 and am trying to figure out what eye is the front and what eye is the rear. I bought the kit from LMC that has the two piece bushings and shackle for the front and the metal\rubber\bolt for the rear but I do not remember what orientation the springs need to. From my measurements, they are the same distance from ping to the center of the eye.
Do you have any pictures with measurements? Also, where can it get 5330 and 5334 and the nut and bolt for those?
Parts catalogs do not list measurements. I need to know the number of leafs to look up 5330. Will then look up the hardware.
8A-5334-A .. Spring Clamp Rubber Liner / Obsolete
Front & Rear: 1957/60 F100/250; 1963/64 F100 // Rear: 1949/59 Ford Passenger Cars; 1955/60 Thunderbird.
No Ford dealer or obsolete parts vendor has any, none on ebay. It may be reproduced, you'll have to look in Carpenter and etc. repro parts sellers catalogs.
Make sure that you don't remove or damage the sheet metal reducer in the front spring eye or the new bushings won't fit. Ask me how I know. I did find an Energy Suspension bushing that was the correct dimension without using the sleeve.
