Gauges and tablet help
Old Feb 4, 2019 | 12:08 PM
Squirrel13's Avatar
Squirrel13
2001 Excursion 7.3 4x4 Limited 231K miles
I have Glowshift Max Tow gauges for EGT, Trans temp, Oil temp, Coolant temp and boost. I was thinking of replacing the boost gauge with a Glowshift fuel pressure gauge and adding Banks Data Monster as it can display up to 8 gauges at once. I would use it for the less critical things and data logging. I have an old Ipad mini I could use with an OBDii solution like torque pro, however it seems that an android tablet is the way to go here. I like the idea of the Banks being in the dash and out of the way. Ipad/android would have a bigger screen but then I have to deal with mounting it. X will be dragging a rock crawler to trail heads on forest service roads. This bouncing may prove cumbersome for the tablet solution. Opinions on the Banks vs tablet
Electronic gauges
EGT
Trans temp
water temp
oil temp
fuel pressure
https://shop.bankspower.com/i-2760-6...%7Cyear%3D2001
Old Feb 4, 2019 | 12:55 PM
unleashd's Avatar
unleashd
This is a cool concept. I would go for the iDash instead of the Android tablet.
Old Feb 4, 2019 | 01:00 PM
PrescottIce's Avatar
PrescottIce
I have an Android head unit, it gets used to view a gauge suite via TorquePro far more than it gets used as a stereo, GPS, backup cam, or phone interface.
Old Feb 4, 2019 | 09:42 PM
uglypitbull's Avatar
uglypitbull
Not sure what your budget is like....but check these guys out. https://www.xploretech.com/us/rugged...ct-resistance/
Also, you will have more software options for additional features with an android tablet.
Old Feb 20, 2019 | 02:21 PM
01__Excursion's Avatar
01__Excursion
Electronic gauges
EGT
Trans temp
water temp
oil temp
fuel pressure
Did you dig deeper into this? Your thread has been tugging at me since reading about the iDash DataMonster. I have been interested in this too, but they do not have a non Can-Bus gauge out yet, the current iDash gauges are for Can-Bus systems, which started around 2008, maybe a little sooner. The 2001 7.3 definitely does not have Can-Bus. They say that they will probably have an iDash non Can-Bus released mid to late summer 2019.
Old Feb 20, 2019 | 02:24 PM
Squirrel13's Avatar
Squirrel13
I called Banks and they said a 7.3 version is in development. They are hoping to release in 90 days but will probably be like 6 mo. I am going to leave a gauge spot for it open in my 650 panel. I will have a CB and Ham radio to mount as well so I doubt the tablet will fit in.
Old Feb 20, 2019 | 06:12 PM
01__Excursion
That's the response I got from them too. The readily available values/readings present at the OBDII will be read by the iDash, they told me that other values/readings that require them to write the software to find a path to those is an unknown. So if you want readings on fuel pressure, oil pressure, Ect, it may require additional sensors with their hub to interface with the iDash. My takeaway was the Isspro gauges I recently installed should suffice.
Old Feb 20, 2019 | 09:52 PM
Squirrel13's Avatar
Squirrel13
I have all the main ones covered. EGT, oil temp, trans temp, coolant temp, fuel pressure and boost. Would be nice to see HPOP and a few of the duty cycles. I’ll still leave a hole for rhe idash. In the mean time I have a ipad mini and a galaxy s6 I can use with torque pro. If torque can see them I would imagine an idash would.
zell66
All Things Towing
Jun 7, 2019 04:19 PM
hawgystyle
Oct 19, 2011 06:44 PM
damuddog
Jul 15, 2008 12:33 PM
dieselsmoker
Jun 3, 2008 06:33 PM
Deluxe05
Oct 28, 2007 08:00 PM
