6.2 motor swap
Well the higher torque and HP is not ONLY related to the engine, but the PCM (powertrain control module, as a generic description) that manages it, along with all the sensors, etc. Just swapping the motor won't likely get you any more power.
If you took the entire harness and engine computer and swapped that with the engine, it might work, but then you have to worry about integrating the "new" engine computer to the "old" chassis.
There are all kinds of things that all these systems do as integrated functions.
I seriously doubt it's as easy as you'd hope it to be.
Ford documents indicate the MY2017+ 6.2 has different cam profiles and a different intake manifold. Another possible interface issue might be with the AT: Ford used the 6.2 + 6R140 combo in the 2011(?)-2016 F250, but switched to the upgraded 6.2 + 6R100 starting in MY2017.
HTH,
Jim / crewzer
HTH,
Jim / crewzer
