NEED HELP!!!
Old Jun 25, 2001 | 06:09 PM
Hunter64's Avatar
Hunter64
NEED HELP!!!
I have a 1989 F-150 4x4. The rear end has been changed and it has a different gear ratio than the front end. How can I find out what the orginal gear was in the rear end?
Old Jun 25, 2001 | 07:20 PM
billyb's Avatar
billyb
NEED HELP!!!
it is probably what is in the front now.
Old Jun 25, 2001 | 07:33 PM
Hunter64's Avatar
Hunter64
NEED HELP!!!
Thanks for the reply. My problem is that there is no identification tag on the front.
Old Jun 25, 2001 | 09:19 PM
larry derouin's Avatar
larry derouin
NEED HELP!!!
Jack up the front end and put on stands with the wheels OFF the ground. Transfer case in Neutral. Lock the hubs. Turn wheel 10 revolutions (SLOWLY) and have someone else count driveshaft revolutions.
Total shaft revolutions divided by 10 = gear ratio.
For example.....if shaft turns 35.5 turns for 10 turns of the wheel you have a 3.55 ratio. 41.0 = 4.10
Larry
Old Jun 25, 2001 | 10:56 PM
PAUL_2's Avatar
PAUL_2
NEED HELP!!!
The vehicle Id tag on the inside of the drivers door should tell you what axle the truck came with . Post the code . It will either be a 2 digit ,IE 25 or 252 . The last two (2) would indicate that there is a limited slip axle .
Old Jun 26, 2001 | 06:08 AM
Hunter64's Avatar
Hunter64
NEED HELP!!!
Thanks for all your help. I appreciate it!!!!!
Old Jun 26, 2001 | 06:41 AM
Hunter64's Avatar
Hunter64
NEED HELP!!!
I checked the inside of the door and the only number found was
H8 axle number.
Old Jun 26, 2001 | 06:43 PM
Mark _G's Avatar
Mark _G
NEED HELP!!!
