Dash pad repair or replace?
Old Feb 6, 2019 | 06:06 PM
donaldwonderly's Avatar
donaldwonderly
An upholstery shop can glue a sandable foam pad to your dash, then sand the foam to the contours of the dash, then glue a new vinyl cover onto the foam,trim the edges, and install the chrome.
Old Feb 10, 2019 | 05:18 PM
Wet Wes's Avatar
Wet Wes
In 63, the padded dash, along with a passenger side sun visor was a “safety package” option. No mention of seat belts.
Old Mar 25, 2019 | 08:21 PM
leeinphx's Avatar
leeinphx
Going with teh metal dash look on my '64.
t1956bird how did you strip the old adhesive off when you did your dash?
My dash pad was completely crumbling so its is now gone. Ford in all its glory glued the snot out of it. Tried some paint thinner, didn't do much. Sanding will take quite a while. Any better options?
Old Mar 25, 2019 | 08:30 PM
Christmas's Avatar
Christmas
Heat gun and a scraper will make quick work of that glue.
Old Apr 18, 2019 | 03:58 PM
Kitter Spater's Avatar
Kitter Spater
Glue removal
Hi, I'm not to classic trucks and the forum. I just removed my dash pad from my 66 F250 CC and it looks great and was very easy... Until, I tried to remove the glue. I've tried Goo Gone, WD40 and a heat gun but can't get it off and don't want to ruin the paint job. Anyone have more suggestions or have had other methods that have worked? The pad is in pretty good shape with one crack, any idea what I should ask for it? Thanks, Kitter
Finished-ish job
Glue residue
For sale
Cracks
Old Apr 18, 2019 | 04:42 PM
Kitter Spater
Glue removal
Hi, I'm new to classic trucks and the forum. I just removed my dash pad from my 66 F250 CC and it looks great and was very easy... Until, I tried to remove the glue. I've tried Goo Gone, WD40 and a heat gun but can't get it off and don't want to ruin the paint job. Anyone have more suggestions or have had other methods that have worked? Also, the dash pad is in pretty good shape with one crack, any idea what I should ask for it? Thanks, Kitter
Old Apr 18, 2019 | 05:03 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
What about gently working up to the edge of the glue using rubbing compound then polishing compound. Don’t be to aggressive. Worth a try.
As to the dash pad? Since they are reproduced ( I believe ) , I would pay exactly zero dollars for a cracked pad.
Old Apr 18, 2019 | 08:30 PM
john jamieson's Avatar
john jamieson
Lacquer thinner, mineral spirits, acetone, goof off. Always try in an inconspicuous place first. Some where in an old thread, people mentioned what they used that didn't touch the paint.
I'm planning on removing my old dash pad too.
john
Old Apr 18, 2019 | 09:22 PM
6t6merc's Avatar
6t6merc
Goo Gone worked for me. Goof Off removes paint, I found out.
Eric
Old Apr 19, 2019 | 12:34 AM
Christmas's Avatar
Christmas
Originally Posted by Kitter Spater
Hi, I'm not to classic trucks and the forum. I just removed my dash pad from my 66 F250 CC and it looks great and was very easy... Until, I tried to remove the glue. I've tried Goo Gone, WD40 and a heat gun but can't get it off and don't want to ruin the paint job. Anyone have more suggestions or have had other methods that have worked? Also, the dash pad is in pretty good shape with one crack, any idea what I should ask for it? Thanks, Kitter
Its better than what I have, What do you want for it with shipping?
Old Apr 19, 2019 | 01:05 PM
Kitter Spater
Thanks everyone. Acetone worked very well.
Christmas, I sent you a message directly about selling the old dash. I'll be gone for a week but can send it to you when I get back if you still want it.
Thanks, Kitter
Old Apr 20, 2019 | 07:17 AM
BarnieTrk's Avatar
BarnieTrk
I know - I'm late to this party, Kitter.
Well, if someone else is still wondering how to clean off residual glue, and you don't have a can of Acetone sitting around, try using your can of charcoal lighter fluid. Dampen the glue with the fluid, wait a minute or so, then wipe with a good terry cloth rag. Repeat as necessary.
BarnieTrk
BORDERBUM
47
Apr 11, 2016 09:18 AM
Med1455
Apr 1, 2016 09:00 PM
Med1455
Apr 1, 2016 08:56 PM
granny_rocket
Apr 29, 2013 06:50 PM
MEDF150
Nov 4, 2009 12:42 PM
