MPH Limiter
Old Jan 31, 2019 | 11:45 AM
Bob Foltz's Avatar
Bob Foltz
MPH Limiter
I have a 2010 F150 platinum. The dash readout started saying Limited to 80 miles per hour. When I approach 75 mph a warning pops back up saying approaching 80 MPH. I thought the limiter was set to 100 mph. Any suggestions?
Old Jan 31, 2019 | 11:55 AM
SCEsq's Avatar
SCEsq
Are you using a MyKey or an Admin Key? I think the MyKey defaults to 80 MPH max.
Old Jan 31, 2019 | 12:23 PM
Bob Foltz's Avatar
Bob Foltz
It is the only key I have ever had. i just has a tech plug into truck computer to try to get HVAC working properly. Since then I started getting messages limiting me to 80 mph
Old Jan 31, 2019 | 01:50 PM
ubereal2's Avatar
ubereal2
It looks like MyKey has been activated, and the speed limit has been set. It will the the administrator key to turn that function off.
Old Jan 31, 2019 | 02:14 PM
Bob Foltz's Avatar
Bob Foltz
Originally Posted by ubereal2
https://www.youtube.com/watch?v=IH_g5gzEsH8
after owning the truck for 2 years it appears i do not have the admin key. Is there any other way to reset?
Old Jan 31, 2019 | 03:19 PM
ubereal2's Avatar
ubereal2
With some digging around, I did find this article. Could be worth a shot, but I have no idea if this will do the trick.
https://forscan.org/forum/viewtopic.php?t=6552
Let me/us know if this does work!
You're local dealer could also do this for you, for a price.
Old Jan 31, 2019 | 03:32 PM
ubereal2's Avatar
ubereal2
If you haven't seen this message before then, this "Tech" may have activated the MyKey on you're truck. I'd have them turn that off/deactivate that.
Old Jan 31, 2019 | 08:00 PM
2jhanna's Avatar
2jhanna
Could this be addressed with ForScan
Old Feb 1, 2019 | 06:51 AM
pantera77's Avatar
pantera77
Yes, I just did it on my 13 I picked up that only had one key and MyKey enabled. Bought a cheap $30 ebay china key, then programmed it through the PATS function on forscan. With the second key programmed you can then turn off MyKey. Plus it never hurts to have a spare key.
Old Feb 1, 2019 | 04:12 PM
Bob Foltz's Avatar
Bob Foltz
Did you buy a key with a chip or just a blank? i guess my problem is I am not familiar with the Pats Function and what is Forscan.
Old Feb 1, 2019 | 10:37 PM
steve(ill)'s Avatar
steve(ill)
You need TWO keys to turn on the system in the truck to PROGRAM a third key.... The DEALER can connect you truck to their computer and REPROGRAM it and get you a second key and make one the MyKey..... FORSCAN is a program you can buy that allows you to REPROGRAM the truck and change several settings... One would be to allow you to make a SECOND key with only having ONE key to start with..
Old Feb 1, 2019 | 10:40 PM
steve(ill)'s Avatar
steve(ill)
Simple thing to do is to go to the dealer and pay $100. to get a second key made and have them turn off the MyKey.... If you think you may have a desire to do additional things in the future, then you might want to look into the FORSCAN system.
Old Feb 2, 2019 | 09:20 AM
Bob Foltz's Avatar
Bob Foltz
REKEY
If all they would charge is $100 I would consider. Try $300
Old Feb 2, 2019 | 03:26 PM
jdunk54nl's Avatar
jdunk54nl
Forscan is free. You would need a usb to obd cable that is $30 on amazon. Then a $100 key (Fairway ford on eBay is a Good choice for a legit key) ford keys are strattec keys (might have spelt that wrong). If you are OK with computers it is fairly simple to just do the PATS reprogram with forscan. Other stuff is more challenging but pats had step by step on screen instructions.
Old Feb 14, 2019 | 08:28 AM
VintageBikesUSA's Avatar
VintageBikesUSA
Are you talking about Fairway Ford in Kingsport Tn? Needing a key myself and saw you mentioned them. =right
