Running the fuel pump
Old Jan 31, 2019 | 10:32 AM
seijirou's Avatar
seijirou
Is there a way for me to run the fuel pump on my 2005 excursion w/ 2004 engine without the engine running? I know it will prime briefly with the key but I want it to run continuously for a while without killing the battery with glow plugs, etc.
I'm sure it can be jumpered at a relay, but I'm not sure where that is. Often times there's a "diagnostic" way to just command the fuel pump to run like the mustang example in this image.
Old Jan 31, 2019 | 01:11 PM
namnguye's Avatar
namnguye
Put 12volt into the the orange wire on the right hand passenger side. It's inside the vehicle, passenger foot, there is a plug with 2 wires. Remove it and put the 12 volt on the orange wire.
Old Jan 31, 2019 | 01:29 PM
seijirou's Avatar
seijirou
Thanks. That's what I ended up doing, putting power to the plug for the intertia switch. The wire was pink/black but maybe that changes by year.
Old Jan 31, 2019 | 01:36 PM
TooManyToys.'s Avatar
TooManyToys.
2003 Version.
Old Jan 31, 2019 | 02:08 PM
Yahiko's Avatar
Yahiko
The C+VCM or VCM2 with IDS will let you do that and I think some of the other higher end diagnostics tools will also.
Would be worth looking into to see if https://www.forscan.org/home.html
Would be worth looking into to see if it will also do it.
anthonym92
Jul 10, 2017 08:36 AM
Tuckering
18
Sep 29, 2015 07:47 PM
Breaker Breaker 3-3
Jan 27, 2013 12:58 PM
capitanjo
19
Nov 29, 2011 04:50 PM
Jrog86
Electrical Systems/Wiring
Nov 14, 2005 01:21 PM
