7.3 Glow Plug Relay Cycle Time Depends On Oil Temperature
Seems to me this is a key in resolving your issue. With your block heater unplugged for a while (or all day or even overnight) i.e. when the engine is cold, slide under your truck on your back just behind the front driver's wheel and touch the area just above and to the side of the oil filter (towards the front of the vehicle) You'll see a cord going into your engine block there ... that's the block heater cord. The area you touch should also be cold.
Then, plug in your block heater, wait for about 15 minutes or so (longer if you wish), then go through the same procedure (touching the same area). If your block heater is working, the area will feel warm to the touch. If its not working, it'll still be cold. That way you'll know whether your block heater is working or not. Next, you need to carefully look at your entire block heater cord to determine if it is the cord that is bad (it was on mine) or if you need a new block heating element ... or both. Of course, this assumes your power supply (via extension cord) to the block heater cord is working correctly.
I am looking for info on a 2000 f250 7.3 I am trying to replace the water in fuel sensor module. did it several years back but don't remember the location. last time I took the complete glow plug wiring harness apart, don't want to do that again. It was either in the valley of the motor or it was under the fuse box. can someone give me the location so I don't have to take everything apart. Thanks
Yes HD rider is correct about the water in fuel sensor. However I am seeking info on the water in fuel sensor MODULE it takes the signal from the sensor and distributes it to the glow plug wiring harness and to the light in the dash. when it malfunctions you get false reading (whether the sensor is plugged up or not) and the ending shuts down.
Codeman894
09-28-2017 08:59 AM
dns340
08-13-2007 05:18 PM
