Speedo not working?
Old Jan 30, 2019 | 08:01 PM
barkfarm's Avatar
barkfarm
Speedo not working?
Speedo stops working when you push the fuel petal down.
Old Jan 30, 2019 | 08:05 PM
Conanski's Avatar
Conanski
Sounds like fun.
Old Jan 30, 2019 | 08:20 PM
will400429's Avatar
will400429
Cool cable driven or eletrictronic?
If it is cable operated try checking the speedo gear. it is located on the left side of the trans at the tailstock. I replaced mine on my 1989 f350. I believe it is held in with one 10mm bolt. Remove the bolt and pull the cable out of the trans. There should be a gear on the end. The gear is held on with a clip at the base of the gear. If it is an electronic sender try checking the sending unit. I believe it is located on the top of the rear end. Hope this helps, let me know and good luck
Old Jan 31, 2019 | 07:31 AM
subford's Avatar
subford
Maybe a rear end bearing problem with your 1992 F-350 truck.
Squarebody
Oct 22, 2013 12:16 AM
mchild
Aug 31, 2003 12:35 AM
offroad72762
Apr 23, 2003 08:59 AM
Ray D
Aug 22, 2000 12:10 PM
