More AC vent problems
Old Feb 3, 2019 | 12:53 PM
Franklin2's Avatar
Franklin2
Originally Posted by kr98664
​​​​​My '84 has the Sanden (barrel-shaped) compressor. The sticker (and the manual) specify 48 ounces (+/-4) of R12. Applying the 80% factor, I used 40 ounces for the R134a conversion and that has worked very well.
I hope I haven't scared off anybody by discussing how much refrigerant to use. It doesn't have to be hair-splittingly precise. The only thing I wanted to get across is that the pressure gauge doesn't correlate to quantity. Remember, refrigerant under pressure behaves very differently than "normal" gasses like the compressed air in your tires.
The method I use is very scientific and precise; I wait till a good warm day, bypass the low pressure switch, and start filling. I make sure the windows are down in the cab. When I hold my hand in front of the vent, and the cold air starts hurting my hand, I know I am good.
If you have a leaky system that you have to fill each spring, you get used to filling it without getting too precise. You would be surprised how much latitude you have with the amount of refrigerant and it will still work.
Old Feb 5, 2019 | 10:59 AM
jackietreehorn's Avatar
jackietreehorn
I think I used about 2.5 pounds. Better to under fill than over.
Niki Farmgirl
Jun 9, 2018 06:21 AM
merlynr
Apr 8, 2010 10:52 AM
Chance_Thomas
May 10, 2006 10:18 PM
Larry00351
1978 - 1996 Big Bronco
21
Sep 19, 2004 10:13 PM
wrh
Oct 19, 2003 07:49 PM
