ac compresser
Old Oct 19, 2003 | 01:01 PM
wrh's Avatar
wrh
ac compresser
My 94 F150 ac compresser switches on and off even when the air is not turned on. The only way it stops is when the heat/ac **** is in the off postion. Is this normal?
Old Oct 19, 2003 | 05:11 PM
Jack01's Avatar
Jack01
is your selector on the defrost postion ?
if not you may have a bad cycle switch. and or a short.
Old Oct 19, 2003 | 05:58 PM
wrh's Avatar
wrh
yes, the control **** is in the defrost position, the compresser will turn on for about 30 seconds to one minute, then go off for about 3 minutes, then repeat this cycle.
Old Oct 19, 2003 | 07:49 PM
fordzrule's Avatar
fordzrule
it is normal for the a/c compressor to run when it is on defrost. its supposed to dry out the air to defrost the window quicker.
