brake question
Old Jan 28, 2019 | 03:29 PM
69oiler's Avatar
69oiler
brake question
Long time no post.
My 03 X has chronic brake problems. most recently, I get both rear brakes dragging combined with a hard brake pedal. Might this point toward a bad master cylinder? I have put new brake calipers on this truck at least once every other year since I got it in 2010.new brake lines and hoses all around. Both rear brakes are dragging...in the past I'd have stuck calipers on one side only.
What do you think?
Old Jan 30, 2019 | 03:28 PM
96firephoenix's Avatar
96firephoenix
I think if you're putting new calipers on every other year, you need to buy better calipers this time so you don't have to do them again in 2 years.
Old Jan 30, 2019 | 05:47 PM
Restlesswildman's Avatar
Restlesswildman
Replace the calipers and brackets at the same time, along with both rear rubber brake hoses and the one on the top of the differential to the hard line. That should take care of anything on the rear axle that will cause sticky brakes. If you can buy calipers with metal pistons. I can not remember if i got metal cups or not. The phenolic(spelling?) pistons swell over time if moisture enters the brake system. That bring up another topic! Bleed the entire brake system until you get clear fluid out of the lines all the way around!
You might want to double check the emergency/parking brake shoes while it is all apart.
Then when the fronts start sticking.....do the same thing minus the emergency/parking brake.
Powerstop brakes sell a nice kit rotors, pads and calipers..
Old Jan 30, 2019 | 08:15 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
replace all the rubber lines. all 5
I chased bad calipers and dragging brakes for a loooong time. finally replaced rubber lines and issues went away completely. the steel braid breaks down and the line will collapse. it will lock pressure in against the caliper.
dwstenersen
Jan 9, 2017 01:46 PM
Chevota_72
Dec 17, 2016 09:19 PM
Coopdc78
Aug 29, 2016 09:50 AM
tworock
Aerostar
Nov 3, 2008 09:40 AM
NH-Hottie
1978 - 1996 Big Bronco
Oct 23, 2003 11:52 AM
