Transmission Shifting
Old Jan 27, 2019 | 04:30 PM
skkzh's Avatar
skkzh
1971 Ford F100
Original 302 and C4 transmission
Truck is supposed to have 41xxx original miles. I believe this is probably correct. When I bought it a few months ago the transmission shifting very rough and down shift very quickly when accelerating.
I changed the fluid and replaced the modulator valve. I believe the fluid was the original and modulator valve too. The fluid was a little dark but did not smell in any way. The filter screen was clean and so was the pan.
now the issue. New fluid and valve and it shifts very smooth. It just shifts very soon. It will shift into 3rd gear around 20 mph. And it won’t drop back to second when I step on the accelerator. I can manually shift it into second and it downshifts very smoothly. The kick down linkage at the carb all appears to be in good condition.
I could not not find a stripe on the original modulator valve. I ordered one from Rock Auto that didn’t have a stripe listed but it came with a WHITE stripe. Will the wrong modulator valve cause the condition I’m seeing? If so, which valve do I need to order? I don’t think the one I have is adjustable.
Thanks!
Old Jan 27, 2019 | 05:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4AZ-7A377-B .. C4/C6 Modulator Valve - threaded type / .12" white stripe (Motorcraft TM-2) / Obsolete
C4: 1964/71 all Ford/Merc Passenger Cars & Econoline / 1965/71 F100/250 / 1972 F100/250 & Econoline before serial number P60,001.
C6: 1966/71 FoMoCo Passenger Cars; ditto 1972 before production date 7/17/72 // 1968/71 F100/350; ditto 1972 before serial number P60,001.
Old Jan 27, 2019 | 07:26 PM
skkzh's Avatar
skkzh
Serial number on my truck is 93522...
Yes it is the thread in type.
Old Jan 28, 2019 | 12:20 PM
NumberDummy
Impossible!
Serial number is the last 6 digits of the VIN .. 1967/77 has a letter followed by 5 numbers.
You omitted the letter.
Old Jan 28, 2019 | 10:00 PM
skkzh's Avatar
skkzh
Sorry - L93522
Old Jan 28, 2019 | 10:07 PM
ford390gashog's Avatar
ford390gashog
Your valve should be adjustable, you also need to fix your kickdown.
Old Apr 20, 2019 | 09:09 PM
skkzh's Avatar
skkzh
So the issue was the check valve and spring came out when I removed the filter. I did not see it until several weeks ago. I found the spring in the bottom of my drain pan but no ball or valve. I ordered this:
https://www.rearcounter.com/D5AZ-7E3...rts191904.html
I finally installed it about 2 weeks ago. Shifts smooth now and the kick down works correctly. Thanks for the help!!!
Old Apr 21, 2019 | 12:08 AM
GaryKip's Avatar
GaryKip
Thanks for letting us know what caused the problem and how you fixed it. Your post may help members with the same problem in the future.
wtroger
1983 - 2012 Ranger & B-Series
Jul 3, 2018 10:13 AM
SSStang
25
May 29, 2018 08:59 AM
Keithfriend
17
Jul 19, 2014 11:17 AM
john_eldorado
Dec 4, 2005 02:39 AM
