Po100
Old Jan 27, 2019 | 12:40 PM
Jsines75's Avatar
Jsines75
Po100
I have a 13 f150 5.0L it does not run, will try to start but not fire. Only code I could retrieve is Po100. Took MAF sensor and noticed almost like it was burnt inside. Could that cause it not to run? Have had issues with it in the past but the MAF sensor was only dirty. When I had issues with it before it’d run but be very sluggish and shut off
Old Jan 27, 2019 | 01:07 PM
steve(ill)'s Avatar
steve(ill)
PO100 is SOMETHING wrong with the MAF circuit.. Normally the truck will start, but run like crap.. If you Sensor is broken, I would replace that FIRST and then see what happens.
Old Jan 27, 2019 | 05:51 PM
brokenleg's Avatar
brokenleg
I think a relay turns the map sensor on...and it may be stuck on
Old Jan 29, 2019 | 01:26 PM
tiny1's Avatar
tiny1
Moderator & CL
My truck was running fine and I stopped at a stop sign. Tried to move forward and the motor was running really rough and had absolutely no power. Had it towed to the dealer and the MAF went bad that quickly. They replaced it and everything has been fine since.
Old Jan 29, 2019 | 01:46 PM
Jsines75's Avatar
Jsines75
Under further diagnosis, I’m leaning more towards not firing. I know it’s not good for the engine but gave 2 little sprays of starting fluid and still didn’t run. It cranked faster off the starting fluid but did not run. Any ideas? Just replaced spark plugs 3,000 miles ago. And replaced #8 coil. I have desired fuel pressure
Old Jan 29, 2019 | 10:18 PM
steve(ill)'s Avatar
steve(ill)
if it is not firing, I would think you would get some CODE........ crank position sensor , etc.
Old Jan 30, 2019 | 09:28 AM
Jsines75's Avatar
Jsines75
Diagnosed the problem, a simple corroded wire going to the fuel pump driver module located on cross member under bed near spare tire storage
bob8619
Apr 22, 2012 03:58 PM
musickerns
1997 - 2003 F150
Jun 16, 2009 06:35 PM
pike_hunter
1983 - 2012 Ranger & B-Series
Jan 19, 2006 10:33 PM
deppdog
Oct 22, 2005 08:22 PM
eldo
3.8 & 4.2L V6
Aug 18, 2004 03:30 PM
