strange howling/drone
Old Jan 28, 2019 | 09:47 AM
RaymondIV's Avatar
RaymondIV
Not necessarily, the noise still could be in the transmission. And if it WAS a bad input shaft bearing the only way to check it is with the transmission removed.
Old Jan 28, 2019 | 07:45 PM
tater3000's Avatar
tater3000
Well boys, I think I found the problem. Steady bearing is thrashed I'm going to see if my warehouse guy in the pipeline can grab me a new one and swap it out after work. will report back
Old Jan 28, 2019 | 11:51 PM
'88 E-350's Avatar
'88 E-350
Steady bearing?
Old Jan 28, 2019 | 11:58 PM
tater3000's Avatar
tater3000
Maybe you know it as a carrier bearing or a Center bearing? goes on the dive shaft. Up here It's referred to as a steady bearing in most shops.
Old Jan 29, 2019 | 10:30 AM
RaymondIV's Avatar
RaymondIV
I don't have a van so yours may be different. But just a warning if you're pressed for time, when mine went out in my pickup I ended up having to take my driveline into a machine shop and have the old one pressed off and new one pressed on.
Old Jan 29, 2019 | 10:39 AM
tater3000's Avatar
tater3000
I found a shop in the town I'm working willing to do it after hours for me, u joints I can handle but I've played that game before with the steady bearing, I did the same as you
Old Jan 30, 2019 | 01:36 PM
tater3000's Avatar
tater3000
All fixed boys, steady bearing, did the u joint to while the shaft was out.
trevorrules
18
Aug 15, 2018 12:57 AM
7.3 Ex
Dec 31, 2011 02:06 AM
7.3 Ex
Mar 13, 2011 06:27 PM
5.4L to Freedom
Dec 18, 2009 09:22 PM
jwtaylor
26
Dec 11, 2004 06:35 PM
