Fuel pump info
Old Jan 26, 2019 | 12:07 AM
HillBillyBuddha's Avatar
HillBillyBuddha
Fuel pump info
1959 F100 223..Fuel pump has vacuum tubes on top for the wiper motor and a glass bowl on the bottom. Anyone know where to get a rebuild kit? Or who makes the fuel pump? Not sure I'm going to keep it original but have glass parts on my engine looked pretty cool. But I don't really need the vacuum lines because I'm going to replace the wiper motor anyway.
But I would like to keep it if the rebuild kit is available.
Old Jan 26, 2019 | 07:38 AM
milkstake's Avatar
milkstake
I bought an aftermarket pump from autozone that seemed to work fine. I think it was like 50-60 bucks. Easy and fast replacement
Old Jan 26, 2019 | 09:23 AM
Tedster9's Avatar
Tedster9
Fuel pumps sure can be more of a problem these days than they ought to be. NOS rebuild kits, if available, may not handle modern gasoline blends. They are now old in any case, and may not hold up to any gasoline for that matter. First thing to do though, is find out what you have, with a valid Ford part #. It's probably a Carter "X" or something like that. There may be some service replacement pumps still available from dealer closeout sellers on eBay. I found a glass bowl w/filter Carter for my slick. No telling how long it will last with modern fuel though. The output pressure at least, is in perfect spec though. More on that later.
There are also rebuilding services from outfits that use modern diaphragm materials that will hold up to ethanol. eBay has a pretty good supply of those vintage pump kits made with ethanol tolerant materials. Even just the sheet material is available. Viton. It's actually a little tougher to rebuild some of them than you might think. Not a show stopper, but. If there are a passle of screws securing the two housings together the pump is rebuildable. If they are just crimped together, it's not really practical.
It is very important that a replacement pump (any fuel pump) be tested for the correct pressure output. Excessive psi is a great way to cause flooding, or even a fire, and many of the import pumps are showing up with this problem. A mechanic's vacuum gauge, which you should already have, also tests fuel pump pressure. One commenter on another board measured 18 psi on a replacement pump! 5 psi is plenty.
Old Jan 26, 2019 | 11:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Does the truck have electric or vacuum wipers?
Old Jan 26, 2019 | 12:01 PM
HillBillyBuddha
It has vacuum wipers but I'm planning on switching them to electric power wipers.
Mcnewt
May 12, 2013 09:35 PM
stevef100
Mar 1, 2009 12:05 PM
1954blueoval
Jan 21, 2006 08:51 PM
cdherman
Nov 6, 2003 07:52 PM
cdherman
Nov 4, 2003 10:30 PM
