Check Engine Light at startup
Old Jan 23, 2019 | 09:27 AM
PSDLOVER's Avatar
PSDLOVER
Howdy Guys. My latest issue is my Check Engine Light comes on during cold start which is weird because it really doesn't get all that cold in S. TX. Once the old gal starts to warm up a little and just a couple minutes later, the light goes off and the truck runs fine throughout. Wonder if it has anything to do with the Edge Programmer I keep on stage 3 - Extreme. Not much to go on I know but even if I brought it to a shop it would be tough to diagnose as it only occurs in certain conditions and only for a few minutes. Troubling though, the check engine on this thing has never been very sensitive and I feel like this may be an indication I need to whip out the old Bucks Bazooka once again.
Old Jan 23, 2019 | 09:40 AM
BBslider001's Avatar
BBslider001
Does your Edge read codes? And get that thing off of there and get some real tuning. Those programmers have been known to cause some real issues.
Old Jan 23, 2019 | 10:45 AM
'88 E-350's Avatar
'88 E-350
Getting the fault code would help. Go back to stock tune and see if it still does it, that's almost always step 1.
Old Jan 23, 2019 | 11:21 AM
PSDLOVER's Avatar
PSDLOVER
I know it. Its just that I had a chip burned here locally prior to much of the extensive work/upgrades I've had done and that six position chip came ajar and fried my PCM. After that came replacing every dam sensor, the injectors, turbo,intake, intercooler - you name it so I never wanted another of those. I in my ignorance had no idea that the thing could just pull out away from the PCM and literally caught it on fire - all while on vacation with my family out West.
bwguardian
Aug 20, 2019 09:03 AM
Dial911
Feb 24, 2013 12:13 AM
donbrown
May 1, 2010 12:21 AM
outdoormaniac
Jan 28, 2008 11:48 PM
^NightTrain^
Mar 22, 2007 08:20 PM
