5.7 hemi vs 7.3 powerstroke
ive got a cold air intake, 4 inch turbo back exhaust, blue fuel spring, drilled out the banjo bolts, and an edge 6 position chip. My truck also has a flatbed idk If that effects the weight much.
yeah that’s what I figured lol. But if you google “2005 5.7 0-60” the best number I can find on a stock truck is about 8 seconds. And doing the test myself I get about 9 seconds and I haven’t put a boost foolery on yet
You lose.
The 5.7 is rated at 345 horsepower at the crankshaft so subtracting the standard of 20% drivetrain loss puts him at about 270 RWHP. Your 7.3 on a good day with stock injectors will only make about that much (nothing you have as a "mod" adds any power except the aftermarket tuning) and your pickup weighs a lot more than his.
You lose.
You may want to go ahead and forfeit the race, then stick around here and learn more about how to modify the 7.3L. The fact that you said "80 horse injector nozzles" was a dead giveaway.
you do know that you can get single shot injector nozzles for the stock 7.3 injector, right?
Apparently you have no clue that you are replying to one of the best early tune writers for the 7.3L, and Cletus being the other insanely desired 7.3 tuners.
As mentioned before tho, unless you are racing while towing trailers up a hill expect to lose. Unless his engine/trans is in very bad shape, or he confuses the gas and brake for a good while when the tree turns green
