1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Toyo open country AT2
Old 01-22-2019, 12:49 PM
GCLL's Avatar
GCLL
GCLL is offline
Can anyone confirm what the largest Toyo AT2 tires I could put on my 2013 F350 FX4 with plow prep? I know the factory 275/65R20 would fit, but what about the "extreme" 35x12.5? Thanks for the help.
Old 01-23-2019, 07:56 AM
89LX306's Avatar
89LX306
89LX306 is offline
The 35's will "fit" if the tire shop will install them. They are technically too wide for the factory 8" wheel. They may rub the radius arms on full lock turns. That said I ran 37x13.50x20 Toyo RTs on my factory wheels for years with a leveled truck.
Old 01-23-2019, 08:00 AM
GCLL's Avatar
GCLL
GCLL is offline
Thank you. I went ahead and ordered them. Did the tire shops give you a hard time?
Old 01-23-2019, 11:39 AM
89LX306's Avatar
89LX306
89LX306 is offline
Discount Tire wouldn't mount them for me. I just took them to a local off road shop and they mounted them up no problem.
Old 01-23-2019, 11:44 AM
GCLL's Avatar
GCLL
GCLL is offline
I had a 2011 with the factory 20" and I put open country MT 35x12.5. I don't know if those were 8" rims or not?
Old 01-24-2019, 07:24 PM
skanj0's Avatar
skanj0
skanj0 is offline
Yes, all of the Ford OEM 20s are 8” wide.
Old 01-24-2019, 07:27 PM
skanj0's Avatar
skanj0
skanj0 is offline
Why not go with 295/65/20s? Better load rating and approved for the oem 20x8” wheels. They are also a tad bit taller than 35s and better fill out the wheel wells.
Old 01-24-2019, 08:02 PM
GCLL's Avatar
GCLL
GCLL is offline
Well I had this size MT before and I was really happy with it and I was able to get the 35 in load range F and the larger sizes are the "extreme" series which is supposed to have slightly deeper tread and a harder compound.
Old 01-24-2019, 08:32 PM
skanj0's Avatar
skanj0
skanj0 is offline
The Toyo specs actually ahow that the AT2 in 295/65/20 is also an Extreme size. It is approximately 0.6” taller than the 35x12.50x20, and the tread depth is actually .01” deeper. The load capacity of the 295 is also over 500 lbs more per tire than the 35” tire.
Old 01-24-2019, 08:33 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Load range F is just a sham and is for flotation tires. The P metric tires like posted above are taller and rated for higher weight. From personal experience the AT2 are terrible snow tires.
The 295/65R20 Toyo Open Country A/T II has a diameter of 35.1", a width of 11.8", mounts on a 20" rim and has 592 revolutions per mile. It weighs 64 lbs, has a max load of 4080/3750 lbs, a maximum air pressure of 80 psi, a tread depth of 17/32" and should be used on a rim width of 8-10".
The 35X12.50R20 Toyo Open Country A/T II has a diameter of 34.5", a width of 12.5", mounts on a 20" rim and has 602 revolutions per mile. It weighs 69 lbs, has a max load of 3640 lbs, a maximum air pressure of 80 psi, a tread depth of 16.9/32" and should be used on a rim width of 8.5-11".
Old 01-24-2019, 09:00 PM
GCLL's Avatar
GCLL
GCLL is offline
Thanks for the info. I'm getting them mounted tomorrow. We'll see how it goes.
Old 01-24-2019, 09:01 PM
GCLL's Avatar
GCLL
GCLL is offline
Old 01-25-2019, 03:18 PM
GCLL's Avatar
GCLL
GCLL is offline
I love how they fit. Thanks 89LX306.
Old 01-25-2019, 03:19 PM
GCLL's Avatar
GCLL
GCLL is offline
Off the truck.
schlepp59
09-12-2010 09:11 PM
levi'sford
33
08-02-2010 08:50 AM
offroadkid
2004 - 2008 F150
11-23-2008 04:13 PM
Arctic Warrior
03-12-2003 09:07 AM
Quick Reply: Toyo open country AT2
