6.2L V8 Discuss the 6.2L V8
6.2 teck data?
Old Jan 22, 2019 | 11:24 AM
alaskantinbender's Avatar
alaskantinbender
6.2 teck data?
Hello guys, looking for some PDF down loads like are found for the diesel engines on other sub forums.
I went over the 6.2 tech file but didn't find any.
Thank you
Jim
Old Jan 22, 2019 | 09:03 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
What specs are you looking for all of them are pretty simple, before 2017 385 hp with 405 torque and after 2017 it was 385 hp and 430 torque. Its overhead cam with variable timing with hemi ceverical heads (think hemi), 9.8 to one compression ratio and two plugs per cylinder. Great motor I pull the crisp put of mine.
If you want to see them go to the Ford site and look for specs.
Denny
Old Jan 22, 2019 | 09:21 PM
alaskantinbender
Thanx for the reply. I'm looking for the ford 6.2 shop manuals. Just finished reading thru the ones for the 6.0 6.4 and 6.7 diesels. Great info on the whole kit and caboodle.
Jim
Old Jan 24, 2019 | 10:40 AM
dnewton3's Avatar
dnewton3
Originally Posted by rvpuller
What specs are you looking for all of them are pretty simple, before 2017 385 hp with 405 torque and after 2017 it was 385 hp and 240 torque. Its overhead cam with variable timing with hemi ceverical heads (think hemi), 9.8 to one compression ratio and two plugs per cylinder. Great motor I pull the crisp put of mine.
Denny
I'm sure it's a typo but the current model is 430 ft-lb for torque; not 240.
Old Jan 24, 2019 | 01:49 PM
rvpuller's Avatar
rvpuller
My bad, I changed it.
Denny
Old Jan 24, 2019 | 06:03 PM
ncl's Avatar
ncl
Denny
Hey Denny I think you meant hemi-spherical. No biggie.
Old Jan 26, 2019 | 07:59 AM
Chuck's First Ford's Avatar
Chuck's First Ford
I do not know of a PDF file on the service manual..
most manufacturers are cracking down on that... its copy - write materiel.. there property .
a few years ago.. HONDA shut-down most, all over the world...
Haynes now makes one... 2011-16.. $ 24.95 most auto parts stores..
or download from Haynes for $19.95.... ( cheap )
with dealers charging 100 per hour.. first time using the book. you save 75 dollars..
pajai
Jun 29, 2008 06:37 AM
78bigunns
Jan 17, 2007 03:53 PM
Frank97F250
Oct 2, 2005 10:57 AM
Lifted94XLT
Kansas Chapter
Mar 27, 2004 12:23 PM
98screamer
Mar 5, 2002 10:56 AM
