02 e250 5.4l temp gauge pegged idiot oil/temp light
Old 01-19-2019, 06:05 PM
sully1975's Avatar
sully1975
sully1975 is offline
Started my van up to get heat, walked inside for 10 min and the temp gauge was far right. The idiot light of oil and overheat was red in the far left of dash.
Didn't seem low on fluid at all. Started and in 3 min back pegged after turning on 2 days later.
No service engine code popped up on dash.
Old 01-20-2019, 07:21 AM
JWA's Avatar
JWA
JWA is offline
Received 1,410 Likes on 1,112 Posts
There's a problem with the instrument cluster wiring----you''ll need to pull the IC out of the dash and check the wiring connectors leading into it. There should be three connectors--sometimes the foil traces on the flexible PCB loose contact.
Most likely this is a ground issue though, nothing too serious.
BTW I own three E-Series, one each 2000, 2003 and a 2005 which has the CAN-bus network which is very different from the 04's and earlier.
Old 01-20-2019, 08:48 AM
alloro's Avatar
alloro
alloro is offline
Received 4,209 Likes on 2,452 Posts
Are you sure the engine isn't getting too hot, or is possibly low on coolant?
Old 01-20-2019, 12:36 PM
JWA's Avatar
JWA
JWA is offline
Naturally that's a distinct possibility too but as I read the OP it seems the temp gauge is pegged and the oi light is illuminated which I failed to consider since my '03 E250 has had the IC changed to a '99 F-Series for the tachometer.
Either way Sully certainly needs to check coolant level and flow.
Sorry for jumping in with possible bum info.
scooter71
3.8 & 4.2L V6
63
07-25-2018 11:27 PM
kincfu
01-31-2016 05:56 AM
JTyler11688
13
05-15-2012 07:09 PM
Todd Dietz
01-30-2006 10:29 AM
Stinger_916
10-07-2003 05:34 AM
Quick Reply: 02 e250 5.4l temp gauge pegged idiot oil/temp light
