E4OD Problems.Gears..No Gears
May I ask...What It cost you?...Did you do it with just a basic rebuild lit..(seals,friction plates,Thrust washers etc.) or did you ended up having to order additional parts ? and did you replace the TC ?
Sorry for the questions..but i cant stop counting my 1.95 till you answer LOl
Thanks
That's correct. With everything unplugged the trans will have fourth gear with the torque converter unlocked.
So break in oil is just changing the original oil early. Got it.
Does something different happen when you keep power to the solenoid pack while disconnecting the MLPS connector? You wont still have 2nd gear in both manual 1 & 2 positions in this scenario?
One Question?.....Should i do the complete tear down, Before ordering any Parts?...do you think this is wise? My Concern here is a 28 year old E4OD If I find that extra parts needed...starts to run..Near a rebuilt Cost..Then I have to contend with trying to return..Not Needed Parts....Your Thoughts Gentleman??
I am Reading Up on a Seemingly Nightmare of These Transmissions With a few sets of Planetary gear assembly's being made of Aluminum..which in a few pulls and Breakdown commentary's always show some Damage...and all say..The Steel ones should have been put in there.
In any Case..It may be slow pokin But i will keep Posting as I go, for those curious
Thanks to all of you cats...Be Safe
That's correct,you can remove the electrical to the trans and you should always have reverse (nothing in D) along with 2nd gear in either the manual 1 or 2 position.
Yeah,I dunno why I said "nothing" in D,instead of high gear though.That was definatly incorrect.Too much on my mind yesterday I guess.
He's not answering whether or not he has and keeps 2nd gear at all times and I dunno why.Sure would be a bummer to tear a trans down,reman and have same problem.He may not know he still has high gear,if he's not pressing hard enough on the skinny and since his eyesight isn't the best anymore,maybe he's not seeing the glowing od cancel light?
Hook up a set of gauges and see if makes pressure.
The manual for the transmission has a very specific sequence of tests to verify condition.
After you got 28 years of service from the transmission it is difficult to understand your attitude. You have a great transmission there, fix it and run it another 28 years. It will outlast the rest of the truck.
But What is it about my attitude..that you can't Understand? I am On here asking for advise, The truck is in good condition because I have taken care of it, Ordered a Dodge challenger just out of the USMC in 73'.. paid 4,200 bucks for it,.In 1990 i used the challenger as a down payment for this truck.....Outside of the Transmission This truck never saw the inside of a shop since it went off warrante
I am not, nor do i profess to be any kind of transmission Mechanic..So I suppose No Matter how well you take care of it...This Transmission WILL need to be yanked and service...every 80-100K miles, from then to now..it has been pulled out of the truck..3 times...First time...Just off warantee period..costing 28-2900 bucks..then...pump seal went out ...Still under warrantee with AAmco....they took care of it ..but i had to pay for all parts....Then...4 years later..Pump seal again..I was lucky this time..it was only like 350...And now...Who Knows whats gonna happen next?...I understand,,part wear..Clutch/disks..You would think, They could have been built or designed a bit better for longevity..After all its costly
I know..some transmissions..not even taken care of...End up going to the junkyard after many years of service..and right to the end..they run..Like Chrysler "Torque-Flight"
I enjoy actually..to own a piece of machinery,,well engineered..to a point..if taken care of..They last for ever.. Not complaining..and i am no licensed engineer...But..I Believe Ford Could have produced a Much better engineered transmission, If they wanted to..Just Saying...does all this..help you understand my Attitude?
I hope you get it
For those Curious..got her down here this afternoon..off the hook...Makin lots of prep..Got her jacked in the air..Tomorrow..will do some tests..then put the wrench to er
E4ODs do NOT need a rebuild every 100K. That's BS. Pulling more than designed after 200K is normal.
Newfoundland? USMC? No stranger to adverse conditions.
This isn't a personal thing with you. I've read a bunch of threads here over the last 20 years or so. People want to put problems on E4ODs where there no problem. Be sure that's not what is going on here.
Are you on here to criticize people condescendingly? or here to help people?
I'm Sorry..But i didn't see anything Useful..about Judging my Attitude
Every Thing Is Disconnected, Except Bell housing bolts,,,She will come down tomorrow ...I decided To drain The pan, Pan had very little debris in it, However...I kinda got sick..when I saw the last..PROFESSIONAL,,That had my tranny down..never put my Magnet back in the pan..Fluid Wasen't To Bad...I Ran Some, Pressures before shutting it down...Crazzzzzy...Warming up..at 65 PSI In Park....And made its way to 180 PSI after 5 min of running...Then shifted thru the gears..eventually..Just got 35 PSI no matter where i put her..Pump/TC..making a bit of a Racket.
I will dissect...the filter tomorrow
I will try and shoot some pictures tomorrow If Anyone is Interested
