Driving to Texas to pick up my new SuperDuty on Saturday. Going to buy 35s next week (Toyo M/Ts or Nitto Grapplers depending on price). Which level to get??....2"BDS with 4 Fox shocks or 2.5" Ready Lift. BDS is more expensive but I would be getting Fox shocks all the way around. Both have track bar relocation.
Is the ride on the factory shocks bad enough to warrant going with the Fox shocks? I live in Louisiana where the roads are God awful if that helps decide...
bds and fox schocks, dual rate new sorings and stabilizer bar ! New conteol arms i believe come with the 2700 dollar package. What my local shop recommending, he knws i am picky
Another vote for the BDS. It comes with the caster correction shims as well and I don't think the ReadyLift does. Your caster will be low after leveling, and if you don't correct it it can cause death wobble or vibrations at certain speeds.
I`m not sure if this matters to you because the difference is very small and you won`t notice it but, did you know that Nitto Tires actually run a bit smaller width wise than the actual size they have listed on the tire?
BDS for sure. The Fox shocks will make your truck ride like it's supposed to and I know the roads in your area well. Just like the roads up here. The improvement will be felt the first few miles and only gets better. It is literally like driving a different truck in how it handles.
Didn’t know that. How about height? Do they measure a true 35?
You wouldn’t believe how many differing opinions the mechanics have around here on the Fox. Many say they are over rated and only needed for off road or if I’m riding gravel roads a lot.
What if I ran a Readylift 3.5 SST lift instead of the leveling kit. Would you see a problem running Fox shocks with this setup? I’ve tried to find Fox 2.0s made for a lifted truck but can’t find them. Would I just order the model for a stock Superduty?
You haven't tried very hard. Go to www.ridefox.com and put in your vehicle specs. It will give you a list of shocks including ride height vs stock. Match up to the lift you are wanting. Stock shocks will be too short.
It is very common for a mechanic to push his products and bash the ones he either does not or can not carry. I've never understood this approach in any kind of business because they lose the best customers this way as they become informed and find out the bias (read lies and misinformation) have caused them to make poor decisions over time. Typically the first thing I do is research any kind of claim one of these guys makes or just listen to him talk and answer my questions. Let them run that trap long enough and it will become clear if they know as much as they think. Lol.
Wish it wasn't that way in all things of life but Reagan had it right way back in the day....Trust but Verify.
