Front center brake hose
Old 01-15-2019, 08:03 PM
FMXconvert's Avatar
FMXconvert
FMXconvert is offline
Trying to find the center brake hose for a '76 F150 4x4. This is the hose that goes between the proportioning valve and the front differential. I have found Dorman H36809 and a pic on Summit's website showing the exact hose, but everywhere shows it as obsolete. If this is no longer available, what are you guys using in its place? I am sure I can fabricate something, but hoping there is a replacement out there. Thanks in advance!
Old 01-16-2019, 06:46 AM
ranger140892's Avatar
ranger140892
ranger140892 is offline
I checked Jeff's and other sites. No luck. But don't fret, you can buy those T blocks, banjo fittings, and premade hoses at Summit and other supply sources. I made up a couple for a Scout that way. Or maybe Number Dummy knows where a NOS hose is. Either way it won't be a show stopper for you.
Old 01-16-2019, 11:44 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by FMXconvert
Trying to find the center brake hose for a '76 F150 4x4. This is the hose that goes between the differential (proportioning) valve and the front differential. I have found Dorman H36809 and a pic on Summit's website showing the exact hose, but everywhere shows it as obsolete. If this is no longer available, what are you guys using in its place? I am sure I can fabricate something, but hoping there is a replacement out there.
D5TZ-2078-F (replaced D2TZ-2078-A) .. Brake Hose - Differential Valve (2B257 in pic) on frame to axle / Obsolete
1972/76 F100 4WD; 1976 F150 4WD // No Ford dealer or obsolete parts vendor has any.
Old 01-16-2019, 09:05 PM
FMXconvert's Avatar
FMXconvert
Thanks for the replies! That is the same info I had found but thought it a little hard to believe since about everything else for these trucks is available. Just wanted to make sure I wasn't missing something. No big deal, wont be too hard to fabricate one! I will try to update the thread with what I end up doing. Maybe it will help someone else. Thanks again!
Old 01-16-2019, 09:15 PM
John89's Avatar
John89
John89 is offline
Give Inline Tube a look online. I bet you can come up with a solution.
Old 01-17-2019, 08:57 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,317 Likes on 2,467 Posts
Old 01-17-2019, 12:49 PM
NumberDummy
The ebay seller has the correct part number (D5TZ-2078-F), but is out of stock.
Old 01-17-2019, 01:14 PM
77&79F250's Avatar
77&79F250
Old 01-17-2019, 01:16 PM
NumberDummy
Listed Ford part number is correct, let's hope the hose is.
Old 01-17-2019, 01:26 PM
77&79F250's Avatar
77&79F250
I just dug deep into Inline Tube Ford catalog, page 21 ? They are only showing kits....
Ford Catalog
Old 01-17-2019, 02:26 PM
njdevil77's Avatar
njdevil77
njdevil77 is offline
I will have to see where I got mine when I did my brakes. I know I changed it, will look in my folder when I get home.
Old 01-17-2019, 07:57 PM
John89's Avatar
John89
John89 is offline
For Inline Tube, look at the "hot rodder" catalog and see if you can piece something together.
Ford must have changed the plumbing in 78. The front stuff on mine doesn't look the same.
This is what mine took. Sunsong 220395 from RA. Now that I think about it they were one of the few places that had the center hose.
Could you make this work? Might try a parts store that makes hoses.
Old 01-17-2019, 08:15 PM
NumberDummy
1972/76 F100 4WD & 1976 F150 4WD is one type. 1977 F150 4WD is 1977 only. 1978/79 F150 4WD & Bronco is different again.
Old 01-17-2019, 08:16 PM
John89's Avatar
John89
John89 is offline
Sorry it's the "Street Rod" catalog.
Is that a "T" on the end with the bracket? How does the other end connect to the prop. valve?
I bet you can get the pieces to make one for less than 40.00 from inline.
Old 01-17-2019, 08:30 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
I had mine made, the ends can be saved and used again. See if you have a parker dealer near you. https://www.hoseandfittingsetc.com/p...ke-hose-rubber
Quick Reply: Front center brake hose
