Front center brake hose
Trying to find the center brake hose for a '76 F150 4x4. This is the hose that goes between the proportioning valve and the front differential. I have found Dorman H36809 and a pic on Summit's website showing the exact hose, but everywhere shows it as obsolete. If this is no longer available, what are you guys using in its place? I am sure I can fabricate something, but hoping there is a replacement out there. Thanks in advance!
I checked Jeff's and other sites. No luck. But don't fret, you can buy those T blocks, banjo fittings, and premade hoses at Summit and other supply sources. I made up a couple for a Scout that way. Or maybe Number Dummy knows where a NOS hose is. Either way it won't be a show stopper for you.
Trying to find the center brake hose for a '76 F150 4x4. This is the hose that goes between the differential (proportioning) valve and the front differential. I have found Dorman H36809 and a pic on Summit's website showing the exact hose, but everywhere shows it as obsolete. If this is no longer available, what are you guys using in its place? I am sure I can fabricate something, but hoping there is a replacement out there.
1972/76 F100 4WD; 1976 F150 4WD // No Ford dealer or obsolete parts vendor has any.
Thanks for the replies! That is the same info I had found but thought it a little hard to believe since about everything else for these trucks is available. Just wanted to make sure I wasn't missing something. No big deal, wont be too hard to fabricate one! I will try to update the thread with what I end up doing. Maybe it will help someone else. Thanks again!
X2 on Inline Tube so I hear.
Or DC http://dennis-carpenter.com/m/trk67-...-hoses/c/1249/
Maybe here? https://www.ebay.com/p/NOS-1973-1976...LH/27015005982
Or DC Brake Hoses
Carpenter doesn't have it.
Or DC Brake Hoses
Maybe this one from Rock Auto? https://www.rockauto.com/en/moreinfo...812&cc=1120813
I just dug deep into Inline Tube Ford catalog, page 21 ? They are only showing kits....
Ford Catalog
Ford Catalog
For Inline Tube, look at the "hot rodder" catalog and see if you can piece something together.
Ford must have changed the plumbing in 78. The front stuff on mine doesn't look the same.
This is what mine took. Sunsong 220395 from RA. Now that I think about it they were one of the few places that had the center hose.
Could you make this work? Might try a parts store that makes hoses.
I had mine made, the ends can be saved and used again. See if you have a parker dealer near you. https://www.hoseandfittingsetc.com/p...ke-hose-rubber
