2000 to 2001 7.3 engine.....
Old Jan 14, 2019 | 09:28 AM
12 pointer's Avatar
12 pointer
Good morning all,
Quick question, will a 2001 7.3 change out with my 2000 7.3? I am sure hoping so since it's been bought. Truck is a 2000 and 2 cylinders are are under compression levels I was told and is misfiring.. Time for a replacement.
Old Jan 14, 2019 | 10:29 AM
Walleye Hunter's Avatar
Walleye Hunter
I'm thinking it should be an easy, direct plug and play.
Old Jan 14, 2019 | 11:47 AM
12 pointer's Avatar
12 pointer
Excellent. Thanks for the reply. I sure hope so, I have bought the thing already.
Old Jan 14, 2019 | 01:33 PM
dmd's Avatar
dmd
2001 with probably have PMR though.
Old Jan 14, 2019 | 01:39 PM
12 pointer's Avatar
12 pointer
Thanks. The long block I bought has 230,000 miles on it. Came out of a rollover and tested good as far as a contribution test, etc. I will have to use my turbo, HPOP, injectors, fuel bowl, etc. My HPOP and injectors are less than 2 years old as well as my valve cover gaskets and my glow plugs and relays. My engine is stock as well as this long block I bought. I paid 500 for it. I have only put 56,000 on this truck in 11 years. I am just hoping to end up with a truck that will fire on all 8 cylinders and run correctly when I need a truck.
Old Jan 14, 2019 | 06:44 PM
00t444e's Avatar
00t444e
Check the 01 block to see what connecting rods it has, if it has the Powdered metal rods, it would be a good time to swap a set of forged rods in.
Old Jan 14, 2019 | 06:48 PM
12 pointer's Avatar
12 pointer
Where do you check and what do you look for? Since I am just after a stock running engine, will the PMR rods not suffice? I'll be 50 this summer. Past the horse power game. lol
Old Jan 14, 2019 | 06:59 PM
00t444e's Avatar
00t444e
There is an inspection hole in the block close to where the block heater is, pull the plug and turn the engine by hand until you can see the fasteners on the connecting rods. If it is a stud with a nut it is the foged rods, if its a bolt head then it had the PM rods. The PMRs are fine as long as you don't plan on making more than 400 HP.
Old Jan 14, 2019 | 07:02 PM
12 pointer's Avatar
12 pointer
Thanks much!!!!! I be happy to just make 1 HP. The long block I bought is still on the trailer in the garage straddling a 33 inch truck tire with 4 straps securing its ride home. You have also got me curious about the original engine. What HP is a stock engine?
Old Jan 14, 2019 | 07:29 PM
00t444e's Avatar
00t444e
Stock 2000 model is rated at 235 HP and 500 ft lbs.
Old Jan 14, 2019 | 07:59 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
People can't let go of something that is a non-issue. Don't worry at all about the connecting rods it has.
I made myself a little bet before I opened this thread that by the third reply someone would have to chime in about them. I WON!
Old Jan 15, 2019 | 09:07 AM
timmyboy76's Avatar
timmyboy76
Am i the only one thinking that the original engine has a possible miss diagnose report? O.P..mind saying what 2 cylinders failed? My guess is 3&8. Any visible signs to you, that led you to belive something was wrong in the 1st place?
Old Jan 15, 2019 | 09:14 AM
BBslider001's Avatar
BBslider001
Ditto my brothers......ditto
Old Jan 15, 2019 | 09:41 AM
Pocket's Avatar
Pocket
I'm also going to agree with the last couple of posts.
A stock engine or even mildly modified - PMR vs forged rods make zero difference. That's a non-issue unless you plan to build the motor to make serious power. Even then you're probably taking out the stock forged rods for something even stronger.
The other part is the diagnosis of your current engine. What issues were you having that led you to take it to a shop? For a shop to give a diagnosis of low compression AND misfiring makes me question the shop.
Old Jan 15, 2019 | 01:37 PM
Hussler's Avatar
Hussler
If possible could you post the compression numbers, I'm sure we're all curious? Missing on a couple cylinders could be so many things. Good buy on the engine though.
