Sponsored by: Real Truck
Voltage gauge fluctuating
Old Jan 13, 2019 | 10:57 PM
jordykarma's Avatar
jordykarma
Exclamation Voltage gauge fluctuating
Replaced alternator and belt and after a couple hundred miles volt gauge on the dash started surging almost to redline and back down midway. Headlights and dome are all pulsing even at idle. Checked tension on the belt and even swapped battery to no avail.
Old Jan 14, 2019 | 12:41 AM
Mike189677's Avatar
Mike189677
Probably a bad regulator in the alternator you bought this wouldn’t surprise most of us as the replacement especially the rebuilt ones are pretty low quality. I got a bad rebuilt and new one back to back right out of the box before. You need to address this before you do some damage to the truck or it’s electronics. The proper thing to do would be test with a voltmeter if you don’t have one take it off and back to where you got it tell them what’s happening they may test it or just give you a new one as they know the replacement alts suck.
Old Jan 20, 2019 | 02:16 PM
jordykarma's Avatar
jordykarma
Thanks
Thanks Mike you were right. swapped it out and the problem went away.
Old Jan 20, 2019 | 04:17 PM
Mike189677's Avatar
Mike189677
good deal Jory.
evan_nugget
20
Sep 11, 2020 02:52 PM
bertha66
Aerostar
Aug 19, 2012 11:12 AM
mudfarmer79
Bronco II
Nov 1, 2005 07:19 PM
firebug
Jul 22, 2004 05:47 AM
Timothyap5vm
Aerostar
Jul 28, 2003 07:56 PM
