Sponsored by: Real Truck
Transmission won't shift past second
Old Jan 20, 2019 | 04:24 PM
ymurf's Avatar
ymurf
I have a 2002 F250 V10 6.8L and I am assuming from what I have researched it has the 4R100 transmission. The other day I noticed it was shifting weird while driving and then after we were headed back home it wouldn't shift past second. I made sure I was in D and not 2 so I turned off overdrive and still it wouldn't shift past 2nd. I bought the truck used with 268,XXX miles on it and it has a Jasper rebuilt engine in it but they no longer have the paperwork to tell me when it was done. I know it has a whine in drive and reverse and was going to do the front pump at some point. I did a scan on it at home and it has a P1714 Shift Solenoid A Inductive code. Could it be as simple as a wire issue somewhere or replacing the solenoid? I was just wondering if anyone could tell me if I am headed in the right direction and could give me any input. Also am i correct on the assumption of the 4R100 transmission? It has an E under the TR on the door tag.
Old Jan 20, 2019 | 04:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is the solenoid. That code indicates that when the solenoid is commanded to change, it didn't change. The only way this code can set is when the solenoid is mechanically stuck. Several of my friends were issued a US patent for the software that detects stuck solenoids. It's very accurate.
It is the 4R100 transmission. Get a new solenoid body for it. It cannot be the wiring, it is the solenoid.
Old Jan 20, 2019 | 06:09 PM
ymurf's Avatar
ymurf
When you say get a new solenoid body for it are you referring to a 9 terminal control solenoid or am I able to just replace the one that is bad? The only other transmission that I have replaced solenoids on was my old 2002 Focus and it just had individual ones that I replaced singularly as needed.
Scott Wallace
1997 - 2003 F150
Dec 28, 2016 08:02 AM
Shadetrees
1997 - 2003 F150
15
Jun 3, 2015 10:57 AM
twall_SD250
Mar 20, 2010 09:40 PM
jennkent5454
1997 - 2003 F150
Feb 21, 2010 07:25 AM
