Misfire problem???
Old Sep 28, 2003 | 07:59 PM
bluebombergt's Avatar
bluebombergt
Misfire problem???
How do I see if the plug or wire isnt sparking properly?
Old Sep 29, 2003 | 08:52 AM
Franklin2's Avatar
Franklin2
You can spray a light mist of water on the wires at nighttime, and sometimes you can see it jumping around. If you have a 302, make sure you route no. 7 wire away from no. 8 wire. These are both on the drivers side rear, next to each other, and they are also next to each other in the firing order. So they have a tendency to crossfire.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
