Headliner for supercab
Old Apr 28, 2026 | 08:35 AM
JB Raghorn 78supercab's Avatar
4th Gear
Originally Posted by thatsrealnice
This company is selling them. Pretty pricey.
https://www.ocautocarpets.com/wn-pro...overed-529059/
I appreciate you reaching out. I’m thinking those headliners will be my last option. I wouldn’t be opposed to making one of those fiberglass ones, just curious if it has to follow a curved pattern at all or if flat would work just fine.
Did you order from that site? And was it plug and play instal?
thanks
Old Apr 28, 2026 | 09:18 AM
thatsrealnice's Avatar
thatsrealnice
Headliner
thanks
I have not. Looking at the notches they have on it around outside perimeter, it looks pretty close to what an OEM headliner looks like. I posted asking if anyone had tried it, and had zero responses, so I assume not.
Old Apr 28, 2026 | 09:59 PM
motorsickle1130's Avatar
motorsickle1130
Id considered that item while buying carpet from them, but then saw the price…. More than I paid for carpet. Its basically cardboard, Not cool.
Semi permanent solution. The attachments are just 2” long “Tek” screws for lathe with 1/4-20 fender washers cause the pressboard is so heavy. Couldn’t make it work with the seam at the back. The finished version will probably have a hook and clip hidden in the middle to help support it. I used the original as a template and did the entire thing by myself. It’s doable in a day, just try not to rush it.
The screws at back are probably shorter. It’s just through the support webbing.
Curated Content Editor
1978 - 1996 Big Bronco
Apr 23, 2019 11:45 PM
skibber
WTB - Parts & other
Feb 19, 2018 06:51 PM
lemasters f100
Sep 14, 2013 06:53 AM
ChaseTruck754
50
Mar 26, 2012 04:22 PM
X36
Apr 2, 2006 10:20 AM
