No freakin HEAT!!!! UPDATE ISSUE FIXED!!!
Old Jan 11, 2019 | 02:54 PM
shadows4's Avatar
shadows4
Ok guys I really need some help here. I am at my wits end. I have a 2004 Expedition 5.4L, 278,000 miles on truck. It has front and rear heat, I have no heat in either. Heat worked fine until I replaced the intake manifold due to a check engine light. (vacumn leak). I have flush both heater cores, flushed the cooling system, put a new thermostat in, and made sure the valve on the heater hose before the heater core was opening. I am going to take it to a repair shop next week if you guys don't have any other ideas. Thanks.
Old Jan 11, 2019 | 03:10 PM
Sam I Am's Avatar
Sam I Am
Have you checked the thermostat? As cheap as they are you may as well replace it with a new one.
Old Jan 11, 2019 | 03:15 PM
shadows4's Avatar
shadows4
Oops!!! I went back and added that in my original post. But yes I checked and replaced the original thermostat. The truck runs fine and the heat guage on the truck runs in the middle of the range. Thanks Sam.
Old Jan 11, 2019 | 04:52 PM
projectSHO89's Avatar
projectSHO89
Did you make sure you got all the air out of the system after flushing it? Air locks are pretty common.
Are the heater hoses both warm, both cold, or one of each (for each coolant loop).
This is not a complicated system. you have to have hot coolant circulating through each core then have air that flows through the air portion of the core(s) (heat exchanger). Break it down to the individual elements of what has to work and go through them in order of priority.
Old Jan 11, 2019 | 06:42 PM
shadows4's Avatar
shadows4
The inlet heater hoses get hot. The outlet hoses do not. Water is not flowing through the cores for some reason. When I flushed out the cooling system with the Prestone cooling kit I let the water run for at least 5 minutes. I did see some of the air come out then. I have no way a putting a vacumn on the system.
Old Jan 11, 2019 | 08:15 PM
pdqford's Avatar
pdqford
What did you do to get the flushing water to flow through the heater cores?
And did you flush the heater cores in both directions?
When I did my Navigator I drained it, pulled the block drains, then filled it with water, ran it until it was up to temp and drained.
Kept repeating until the water came out clean. Took TWELVE cycles.
Old Jan 12, 2019 | 10:41 AM
alloro's Avatar
alloro
When I flush I disconnect both hoses to the heater core and run the hose straight to the core. After a bit I switch and run the water through the core in the opposite direction. You'd be surprised at how much gunk comes out sometimes.
Old Jan 12, 2019 | 12:57 PM
shadows4's Avatar
shadows4
I did flush the front core both ways. What gets me is it worked fine before I pulled the intake manifold. I has stopped working since I put it back together. Truck runs better than it has in a long time, just no heat.
Could the water pump possibly be weak and not providing enough flow to push through the heater core but enough to keep the engine cool?
Old Jan 12, 2019 | 03:39 PM
projectSHO89
Yex, it might be a bad water pump (eroded impeller), but the details you reported make me suspect it's a simple case of an air lock in the heater loop ... unless something got put back together wrong...
Old Jan 13, 2019 | 07:53 AM
alloro's Avatar
alloro
Any chance you put any of the hose back wrong?
If the water pump was an issue I'd think it would've been an issue before you took the manifold off.
Old Jan 18, 2019 | 05:26 PM
shadows4's Avatar
shadows4
Just wanted to update. I haved replaced the water pump and the radiator. (Radiator had a leak anyway.) No change. I took it to my local garage and had them evacuate the system, flush and fill. No change. The inlet to the heater core does get hot, the out let does not. One thing I didn't mention before. The return pipe for the heater core that goes under the intake manifold was leaking. I tried the youtube hack where I cut the pipe, installed an elbow and ran some heater hose around the outside of the block to the rear of the engine. The only thing I can think is that hose has gotten pinched under the intake stopping the return flow from the heater cores. Soooo I am going to order the correct part and fix it the right way. Damm the bad luck. I should have known better and fixed it the proper way to start with. Thanks guys.
Old Jan 19, 2019 | 09:32 AM
alloro's Avatar
alloro
Good luck and let us know if that fixes it.
Old Jan 23, 2019 | 06:53 PM
shadows4's Avatar
shadows4
I HAVE HEAT!!!! I went back and removed the youtube fix I had used. There just isn't enough room under the intake for the elbow and heater hose I used. The reason I used it is because I had read somewhere that the replacement pipe was around $150 bucks. Never checked. I know I am an idiot. Bought the replacement pipe from the dealer for around $30 bucks. Any way I want to thank you guys for all the replies.
Here is a good youtube video I used for guidance removing the intake manifold.
Here is the you tube video I used to bypass the heater return tube. My manifold doesn't have as much room in front as this one does.
jerryparks
2004 - 2008 F150
17
Jan 19, 2019 08:24 AM
Reaper21
Feb 11, 2016 06:48 PM
Murf_2002_F150
1997 - 2003 F150
31
Dec 16, 2013 09:31 AM
98expedition98
Mar 10, 2007 09:04 PM
Terran
Sep 10, 2005 06:24 AM
