Heat Problems
Old Feb 9, 2016 | 08:47 PM
Reaper21's Avatar
Reaper21
Heat Problems
So I'm new to the site I have a couple issues with my heat in my 2000 F250. I've replaced thermostat, heater core, not sure what else to do. Its cold in PA lol Any thoughts??
Old Feb 10, 2016 | 06:48 AM
projectSHO89's Avatar
projectSHO89
You going to tell us about the "issues" or should we just guess?
Old Feb 10, 2016 | 08:10 AM
Reaper21's Avatar
Reaper21
I have no heat, everything seems to be working correctly but it blows cool air doesn't get hot. I replaced the thermostat and the heater core I filled it up with coolant ran it for an hour and still blows just cool air. I did work all the air out of the coolant system.
Old Feb 10, 2016 | 02:31 PM
projectSHO89
You seem to misunderstand (or, at a minimum, have failed to report) the fundamental fact that HOT COOLANT MUST FLOW THROUGH THE CORE(S).
Until you have verified that, you're wasting your time by not properly diagnosing the fault.
Old Feb 11, 2016 | 06:48 PM
John L Simmons's Avatar
John L Simmons
Intermittent heat
Expedition 2003 5.4 with intermittent heat. Have replaced thermostat, heater control vlv, checked hoses and inspected wtr pump ? When not blowing hot it will sometimes overheat, bowling over from reservoir. At these times the hoses are cold as well ?
Any suggestions
shadows4
Jan 23, 2019 06:53 PM
mlelah
26
Jan 10, 2015 02:27 PM
uscgmkcret03
6.7L Power Stroke Diesel
Feb 21, 2013 10:17 AM
handthill
Mar 4, 2012 07:20 PM
Hay Farmer
Jan 29, 2010 12:47 PM
