OBS 250 Front Leafs
Old Jan 11, 2019 | 09:40 AM
Franco802's Avatar
Franco802
OBS 250 Front Leafs
So I am going to replace the front leafs on my 1993 f250 4x4. It shows my spring code is 6F which are the weaker front springs. There are a few choices on Rock Auto and one of them being the 3480lb springs instead of the weak 2485lb springs. If I go with the heavier duty ones, will it also level me out??
Old Jan 19, 2019 | 10:14 AM
TobyB's Avatar
TobyB
"Probably."
If you have less than 2 inches of gap under your bump stops, it should.
The stiffer spring may not raise it as much as you'd hope, though, because
it will have less preload built into it.
There is a letter code stamped into the leaf itself- that will confirm what's really there.
Finally, if you have a stiffer spring in front, you'll notice even more 'trucklike'
behavior from it- understeer especially, and you'll want to be careful the first few
times driving it with a heavy load, as it will behave differently.
Me, I'd just try new of what's on there, for starters, unless you want to increase its capacity for other reasons.
hth,
t
Old Jan 20, 2019 | 04:09 AM
Skitter302's Avatar
Skitter302
If your really unsure call the guys at truckspring.com. They were a big help to me.
joe98356
Oct 6, 2015 09:03 PM
carl2591
Jun 14, 2015 06:03 AM
DIYMechanic
Oct 19, 2011 07:39 PM
codyingersoll123
1997 - 2003 F150
Nov 30, 2009 02:32 PM
drydocked
Sep 12, 2004 03:37 AM
