Sponsored by: Auxito
250 LD Springs
Old Nov 28, 2009 | 01:34 AM
codyingersoll123's Avatar
codyingersoll123
250 LD Springs
Im guessing the 97-99 F250 LD rear springs are heavier then the F150's standard springs. Are they the same length and width and just have more leafs ??? or are they a different size?
Need heavier springs on my F150 to tow a boat but dont wanna spend money on a good set of helper springs...hopeing I could get away with stiffer 250 springs easily. Any thoughts or ideas???
Thanks
Old Nov 28, 2009 | 03:25 PM
f150thatpullsalot's Avatar
f150thatpullsalot
The only thing they did different on the 250 was added one extra spring in the back nothing else.
98 f150 4.6 v8
Old Nov 29, 2009 | 07:57 PM
codyingersoll123
perfect...so it will work to help me tow more with my 150!!! =-)
Old Nov 29, 2009 | 08:04 PM
codyingersoll123
Does anyone know the code/part number for a 97-99 2wd ext cab F250 for the rear springs??? Heres what it asked after I searched 99 F250 rear leafs on car-part.com...
Leaf Spring, Rear
Main Spring, (under 8500 GVW), code 2
Main Spring, (under 8500 GVW), code 3
Main Spring, (under 8500 GVW), code 4
Main Spring, (under 8500 GVW), code A (2.5 inches wide)
Main Spring, (under 8500 GVW), code 6
Old Nov 29, 2009 | 08:30 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
I put an add a leaf into my rear spring packs. It was the middle spring i believe and added 900lb of force to it. Lifted the rear of the truck about 2in. I have had 3500lb gravel in the bed of my truck and still have 1.5in of travel to get to my bump stops.
It only costed me roughly $100 from a local spring shop.
Old Nov 29, 2009 | 08:40 PM
codyingersoll123
im not to worried about bed weight capacity im worried about heavy tongue weight. I would like for it not to sag to much when I get a trailer to pull my 79 around. Im not rich so it will probably be some $500 old heavy a$$ equip trailer. My wide mud tires wont fit on a car hauler...
Old Nov 29, 2009 | 09:43 PM
BURNSTOUGHFORD
your amount of sag will be resolved ther same way. The F-250LD just added one extra leaf to the pack i believe. But its harder to pull the leafs out and swap than to just add a leaf into the existing pack.
Spring just generate a upward force on the truck, dosnt matter if its towing or in the bed. Stiffer spring will sag less than a softer spring under the same loads. So if you wanting to cure some sag issues, add a leaf to your spring pack.
Im not talking about the simple bolt on system, im refering to the type that you acutally seperate the leaves in the pack and put another one in.
Old Nov 29, 2009 | 10:23 PM
codyingersoll123
I understand...either way you have to take the springs out...I was just thinking about ease and cost. I went to car-part.com ( a junkyard search engine) and found 250 leafs for 50-75 bucks. I could just swap them right in and save my self hassle of redo-ing stock springs...then I still have stock ones too. I was just wondering if anyone had done it before and if it was worth it...or wether I should go with the extra leaf or helper springs route.
EDIT- where did you get your extra leaf??? and how much??
Old Nov 29, 2009 | 11:29 PM
BURNSTOUGHFORD
I cant remember where i bought it at. It was a local shop that specialized in springs. I think it was $80 and then i bought new ubolts.
Old Nov 30, 2009 | 01:13 PM
codyingersoll123
oh =-( Every shop down here in Naples is expensive...I could do myself, its not that difficult to rebuild a set of springs. if I knew where to find the extra leaf cheap enough it would work.
Old Nov 30, 2009 | 02:32 PM
redwood's Avatar
redwood
Check here: Trail Master Suspension R2160 - Trail Master Leaf Spring Add-A-Leaf Kits - Overview - SummitRacing.com
The Eddie
Jan 19, 2013 04:41 PM
h20fella
1997 - 2003 F150
Aug 12, 2011 10:41 PM
86302f150
16
Feb 12, 2009 10:17 PM
TODDBPARKER
1997 - 2003 F150
May 7, 2006 11:44 AM
