clutch safety switch
Old Jan 18, 2019 | 08:28 AM
patrickg450's Avatar
patrickg450
I am waiting on parts, going to redo all the bushings then rebleed.........
THanks
Old Jan 24, 2019 | 10:39 AM
k1ttlez's Avatar
k1ttlez
Did you ever get your clutch to bleed?
I struggled with mine for days when I did it. The key for me was to do a really good bench bleed, then just a whole lot of gravity bleeding and pumping up the clutch. The most seuccessful time still took me 1 qt brake fluid and 30 mins of pumping the clutch in between gravity bleeds.
Also different truck, 94 f150, 4.9L
My clutch rod was originally plastic, but I replaced the master cylinder and it came with a solid metal arm. I retrofitted the arm, but now the interlock stays stuck on all the time because the retrofit clutch arm/eye shoulder is too fat.
Old Jan 24, 2019 | 02:36 PM
patrickg450
Well sort of.......
I got it to where I could move it out of the garage. I still need to do it again as there is room for improvement. My pedal bushing are bad so I am waiting on parts beofre I do another bleed. I am trying to NOT take off the slave cylinder and do a bench bleed, but it may be my only option.
dogdays
Oct 17, 2018 02:27 PM
mechelement
17
Jun 3, 2013 06:42 PM
*2fords*
Dec 27, 2009 06:36 AM
ajstephan
Jun 19, 2000 12:57 PM
