Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
I'm confused.
Old Jan 7, 2019 | 07:35 PM
brandonbeezy's Avatar
brandonbeezy
I'm confused.
Ok, for no other reason than to have it. Im considering buying an f600. I have read around the web stating that under 26001 lbs GVWR i do not need a CDL. Looking at a 1986 sales brochure (I'd like one in the 80-86 my) i see the the 600 is rated 24k gvwr. Now directly below that i see the combined weight is 50k! I understand that gcvwr is truck weight plus trailer plus load weight. Where does that come into play with needing a cdl? I believe if ive read correctly if the load and trailer are 10k or more i need a cdl, but what im asking is with the 50k gcvwr will i be legally allowed to drive this vehicle so long as i keep the trailer and load under 10k? Sorry for the rambling.
biggest truck ive owned was a 88 f350 c&c
Old Jan 7, 2019 | 07:38 PM
brandonbeezy
here is a screenshot of the ratings. Sorry for the quality.
Old Jan 7, 2019 | 07:44 PM
85e150's Avatar
85e150
You are ok without CDL if your trailer is under 10K,
F600s were fine trucks. 30+ years on, you must be very diligent in you pre-purchase inspections. One thing to watch is brakes. New drums are not available, although everything else is.
There is a chance you will run across widow maker wheels, although I'm pretty sure those were gone by '86. Someone could have put them on the truck.
370s are not powerhouse motors. Brakes (back to that) could be Lucas Girling. Look for a yellow pull **** on the dash for the park brake. Good brakes but expensive to work on.
There are dozens of F600 threads here, with links to all those issues, so read on before you get your checkbook out.
Old Jan 7, 2019 | 07:50 PM
ford390gashog's Avatar
ford390gashog
That chart is not correct. The F600 was rated at 32k and the F700 was available up to 42k. Also you have to be under 26k for Class C, that's why you see lots rated at 25,999lbs.
Old Jan 7, 2019 | 07:57 PM
ford390gashog
Depending on your state and unladen weight you can also register the GCWR lower and pay less fees.
Old Jan 7, 2019 | 08:56 PM
fivestarmmd's Avatar
fivestarmmd
It can be tagged for its rated carrying capitiacy of 1 1/2 tons plus empty wt. So if weights 9000 thousand empty plus 3000 for load. This is what I did on F800 I have, empty wt plus 2 1/2 tons..
Old Jan 9, 2019 | 09:19 PM
Destroked 450's Avatar
Destroked 450
Chart is correct, my F-800 is only rated for 32k, never seen a 20k float front axle on a F-700 to make it 40k rated
under 26k truck = no cdl
under 26K truck pulling 10K trailer = no cdl
under 26k truck pulling over 10k trailer = not sure
over 26K truck = class B cdl
over 26k truck pulling 10k trailer = still class B cdl
over 26k truck pulling over 10k trailer = class A cdl.
Old Jan 10, 2019 | 06:33 AM
Spirit of '76's Avatar
Spirit of '76
Call your local state police barracks and speak to the commercial enforcement officer. He/she will tell you what is and is not legal.
Old Jan 11, 2019 | 11:30 AM
brandonbeezy
Thank you guys for the help!
Robe81
2009 - 2014 F150
16
Jul 31, 2013 07:36 AM
fg250
6.4L Power Stroke Diesel
19
Nov 5, 2010 07:26 PM
acheda
All Things Towing
33
Apr 26, 2007 06:03 AM
gabz
All Things Towing
Feb 4, 2002 05:57 PM
johnand
All Things Towing
Apr 5, 2001 07:02 AM
